GT Dies on Road! Help!!
  • Thread starter Thread starter Solosngr
  • Start date Start date Mar 29, 2011
Solosngr
  • Mar 29, 2011
Need help. I have a 95 GT (5.0L) and for the past month whenever I'm driving it will just shut off with no warning. Most of the time it’s when I'm accelerating. In the beginning it would start right back up with no problem but lately it takes about 10 min for it to start back up. At times it will shut off but then before it comes to a complete stop it fires back up on its own. Fuel pump is engaging, I replaced the fuel filter, ignition rotor and cap (they had burns and wear on them). Drove the car for about 30 min shut it off for about 2 hours and it wouldn’t restart. Finally got it going drove another 30 min and it shut off after I was accelerating through an intersection. Any thoughts?
Zero Signal
2,633
Tucson, AZ
Mar 29, 2011
  • Mar 29, 2011
The distributor did that to me. Something went wrong with it internally. Check for spark with a tester.
94GTCoupe
1,412
92
79
CA
Mar 29, 2011
  • Mar 29, 2011
Profile ignition pick-up (PIP),AKA Pick-up Coil.
The distributor must be disassembled to replace it.
I've had good luck with Napa brand PIP.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Mar 29, 2011
  • Mar 29, 2011
I had the same issue with my distributor, but in my case it was corroded contacts on the cap.
Solosngr
  • Mar 29, 2011
The connectors on my cap were erroded also. I replaced the cap yesterday. Got in it about an hour ago and let it run in the driveway for about 30 min. It shut off and now it wont start.
toyman
1,944
54
79
Vernon BC
Mar 29, 2011
  • Mar 29, 2011
I vote for the PIP. Had exactly the same symptoms.
Solosngr
  • Mar 30, 2011
Went to NAPA online to order the part and couldnt find it. Does anyone have a part number for the PIP?
BlackVert
5,589
9
98
Bethesda, MD
Mar 30, 2011
  • Mar 30, 2011
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 30, 2011
  • Mar 30, 2011
Forget about just replacing the PIP sensor. Your 16-year-old dizzy will have advanced wear so you're better off replacing the whole thing with a new Motorcraft unit. Trust me.
91LX_5L
1,943
British Columbia
Mar 30, 2011
#10
  • Mar 30, 2011
  • #10
had the same issue, I replaced my entire dizzy as well, I dont plan on selling the car so its not really a bad idea.
toyman
1,944
54
79
Vernon BC
Mar 30, 2011
#11
  • Mar 30, 2011
  • #11
It's also know as the hall effect sensor. As stated I would replace the whole dizzy if it's 16 years old. There is likely to be wear on the shaft, gear and bushing on the old unit depending of course on mileage.
99FiveOh
2,051
20
99
J-Ville, FL
Apr 2, 2011
#12
  • Apr 2, 2011
  • #12
^this. Just replace the entire thing. By the time you mess with the headaches of replacing that sensor you'll wish you had. Especially if it's your first time! You'll probably get that gear pressed on backwards or slightly off center so the roll pin won't fit back in. Then good luck finding one of those pins if you mess up the old one because Advance and Autozone don't have the correct size!
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Apr 2, 2011
#13
  • Apr 2, 2011
  • #13
+1. Just get a new distributer. There are bearings in there that wear out anyway. I had the same problem, but it was my ignition contrrol module.
Kurt
Solosngr
#14
  • Apr 4, 2011
  • #14
Thanks for all the advice. Replaced the PIP it still didnt work. Come to find out it was the Ignition control module. Could have saved myself about 3 hours!
Dino Dino Bambino
1,673
90
79
Cyprus
Apr 4, 2011
#15
  • Apr 4, 2011
  • #15
Consider it as preventive maintenance. Even if the PIP's OK and it's the TFI module that craps out, it won't take long for the PIP sensor to do the same so you've gained good insurance by replacing both.
My PIP sensor died first in May 2009 and then the TFI module died just 9 months later so my stang had to go on a flatbed twice.
STM1965
185
Ontario
Apr 6, 2011
#16
  • Apr 6, 2011
  • #16
TFI
I fought though this issue last summer bottom line it was the TFI! Drove me nuts! Sometimes its the simplest thing and you get bogged down chasing/changing parts that don't need it!
99FiveOh
2,051
20
99
J-Ville, FL
Apr 6, 2011
#17
  • Apr 6, 2011
  • #17
Odd. I've probably owned 4 or 5 foxes and 5 or so SN95s and I've NEVER had an SN95 burn up a TFI module, however, EVERY SINGLE fox I've ever owned burned up at least 2 or 3. So much that I kept a wrench, tfi removal tool and a new sensor in my glove box, so I could change it on the highway and be on my way if it pooped out on me.
STM1965
185
Ontario
Apr 7, 2011
#18
  • Apr 7, 2011
  • #18
For whatever reason my BBK headers give off a ton of heat to the point that I am considering wraping them which is why mine might have failed.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
CAMTWO1070
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
