GT vs Coupe
  • Thread starter Thread starter undercnstrction
  • Start date Start date Aug 20, 2010
U
undercnstrction
312
  • Aug 20, 2010
so i came across an '87 coupe that is for sale for $600 that is somewhat close to me. the interior and windshield are gone (still waiting to see just how much of the interior is stripped). it does have a motor that will come with it (stock 302) and i'm not sure about the trans. i was planning on building my GT but have really grown to like the coupes. is there a difference in how to the two cars would handle as a finished product? my ultimate goals are to have a comfortable cruiser as it will spend most of its life on the street, but it will definitely see some autocrossing, hopefully some road courses and open road racing. would a coupe be a bad choice for any of that? from what i remember they were a bit lighter than the hatch cars correct? didn't also have a stiffer chassis? any opinions?
also came across an '86 coupe with a v6. how hard would it be to put an '87 5.0 in there, and convert it to 5sp? i know the suspension was different from '86 to '87 but i had already planned on upgrading the suspension/brakes/5-lug on my current car. would the same upgrades work for a 4-eye or are the parts specific to 85-86 foxes?
90limited
276
Port Charlotte FL
Aug 20, 2010
  • Aug 20, 2010
Was it a v-8 car from the factory? If not, make sure you have a new 8.8 rear among other things in your budget.
U
undercnstrction
312
  • Aug 20, 2010
the '87 i believe is/was a factory v8. the 86 is not.
Mustanglvr2006
340
Somewhere
Aug 20, 2010
  • Aug 20, 2010
If I remember correctly the coupes are like 300lbs lighter than the hatch cars, I'm not really sure about having a stiffer suspension tho.
Best of luck
faststang90
522
baytown texas
Aug 20, 2010
  • Aug 20, 2010
the v6 k member is not the same and u would have to change it
Coast2CoaStang
254
  • Aug 20, 2010
I think the v6 K member will work. I believe it's the earlier cars with the inline 6, that need the K member swapped for a V8.
U
undercnstrction
312
  • Aug 20, 2010
i was already seriously considering chaing the k-member on the GT. do you know if there would have to be any modifications done to swap in a v8 after k-member since it was a v6 to begin with? also, do you know if the '87+ suspension pieces are the same as the 85-86 pieces?
Coast2CoaStang
254
  • Aug 20, 2010
You should have no modifications, or problems with installing an aftermarket K member in your car. Yes the 87+ suspension will be different than the 86.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Aug 23, 2010
  • Aug 23, 2010
K-frame interchange is as follows:
Capri '85 Front; from 2/85
Capri '86 Front
LTD '85 Front; 4 cyl and 6 cyl, from 2/85, std duty
LTD '86 Front; std duty
Marquis '85 Front; from 2/85, std duty
Marquis '86 Front; std duty
Mustang '85 Front; exc. SVO; from 2/85
Mustang '86 Front; exc. SVO
Mustang '87-93 Front; 4 cyl
Mustang '87-93 Front; 8 cyl
And yes...the inline 6 K-frame is by itself. The V6 K-frame and V8 K-frames are the same.
U
undercnstrction
312
#10
  • Aug 23, 2010
  • #10
thank you......
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
