GT40 Explorer Intake MAF issues?
  • Thread starter Thread starter SuxToBeMyTires
  • Start date Start date Oct 16, 2011
SuxToBeMyTires
10
  • Oct 16, 2011
I apologize if this issue has been covered repeatedly already. Anyway, I'm talking to a guy who is parting out a 96 Explorer 5.0 engine and am probably going to buy the heads off him (these have the emssions). I am now thinking about buying the upper and lower intake also. I saw a discussion about the tubular GT40 intake not having the MAF and would need a conversion if upgrading the cam (which I am doing). Will I run into a MAF issue with the non-tubular intake taken off a 96 explorer? And if I do, exactly what issues am I facing and is it correctable without an insane amount of work?
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Oct 16, 2011
  • Oct 16, 2011
it wont have a MAF cause the MAF isnt on the intake, its further upstream just behind the airbox. if you mean egr, the 96 might or might not have it(well, it'll have a valve, but it may be externally plumbed instead), no huge deal if it does or not. it also probably wont have a tapped hole for the ACT sensor in the #5 runner, but it would just need to be drilled and tapped easily.
if your car is an 86-88, then you may want an maf conversion, a search here will show you what you need and how to do it.
SuxToBeMyTires
10
  • Oct 16, 2011
Oh, my mistake. Well I know the 96 and under 5.0 have the EGR. Early 97s may have it too. My car is an 89, so would a MAF not be necessary?
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Oct 16, 2011
  • Oct 16, 2011
Again, MaF is not part of the intake. If you swap an explorer intake on, you wouldn't touch your maf.
You mean the EGR. Is it necessary? Well you will lose a little fuel economy, but it can be removed. Try and get an explorer intake with egr to make things easy. Intakes are cheap and plentiful. Going rate is $75-100
1996 should have the egr port anyway.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Base Idle Reset-Accufab
  • 89notchDude
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 22, 2025
Scrapla347
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
