  • 1994 - 1995 Specific Tech
GT40 HEAD BOLTS
  • Thread starter Thread starter JOEGTS
  • Start date Start date Jan 27, 2006
JOEGTS
153
Port Saint Lucie, FL
Jan 27, 2006
  • Jan 27, 2006
I have a set of GT40 heads that I plan to install in the near future and I am unsure of the head bolts needed. I purchased ARP #154-3601 head bolts, but I have read that the bolt holes are larger than the holes in E7's. Does any one know if these bolts will work and do I need to buy some sort of spacer to go with these. They are Iron GT40's. Any info would be appreciated.
Zero Signal
2,633
Tucson, AZ
Jan 27, 2006
  • Jan 27, 2006
Those are the bolts I used. I know other people have used those too. The alignment dowels will keep the head from shifting. But with 70-75 ft-# of torque on those bolts, they aren't going to shift anyway.
JOEGTS
153
Jan 27, 2006
  • Jan 27, 2006
So I shouldn't bother with buying the spacers? Thanks.
illwood
636
Worcester, MA
Jan 27, 2006
  • Jan 27, 2006
John's right about the dowel pins locating the heads, but I would run the spacers. I don't like giving things the opportunity to move in a bad way.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 27, 2006
  • Jan 27, 2006
i think that the 351 heads use a larger hole and bolt but with normal gt40 heads youll be fine
D
db1994
52
Lake Worth, FL
Jan 27, 2006
  • Jan 27, 2006
"Regular" gt-40 heads such as those that come from the factory on a 93-95 cobra have 1/2 inch holes, while the block has 7/16's holes.
You will need the insert washers if you want to do it right. 154-3605's I believe.
-Jason
blksn955.o
3,263
st.louis mo 314
Jan 27, 2006
  • Jan 27, 2006
You only need the bolt hole spacer if the heads are off a 351. The 351 used a larger bolt hole at 1/2in the 302 uses a smaller one.
I have heads off a 95 cobra its a 302 head to a 302 block so they use the same head bolt...no need for hole spacer/tube.
FWIW spend the little extra for the ARP bolts.
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
