gt40 heads and trick flow questions
!989 5.0 convert
ok heres what i have 1989 5.o with an aod
stock bottom
trick flow stage one cam
cast gt 40 heads (tfs spring upgrade) 3 angle grind and surffaced
gt40 cobra intake with 1 in spacer
bbk adjustable fpr
stock injectors
65 mm tb
bbk cold air
stock maf i have a 73 mm but not on it wouldnt idle right with it
bbk headers and mid pipe with high flow cats
NO smog
Problem runs good but when you get on it and you get around 3500 to 4000 it skips a touch not bad but i know im losing power
#2 i have a ticking in my rockers the intake side are fine but all the exaust rockers are lose with the small shims but to tight with no shim
any suggestions
ok now questions do i need to upgrade to #24 injectors and what about the fuel pump
also what should i set the fp at
i plan on getting it tuned but want to get it close before i go also any sugestions one things i need to know or do before i go
thanks for your help
You really should be running 24 lb injectors and at least a 190 lph pump with the fuel pressure set at around 41 psi. You really need to get a tune as well and get a pushrod length checker to make sure your pushrod length is correct.
It could be possible to need a slightly longer pushrod but uncommmon. How are you checking geometry? What rocker arm is it? How's the wear pattern on the valve tip with a sharpie, is the gap .060" or wider? What shim gives it too much preload?
