GT40 intake torque specs
wyominghotwheel
156
Insanemustangs
i am at work so i don't have the sequence for ya, but it is done in 3 steps.........from memory, it is 8ft lbs, 15ft lbs and 25ft lbs..........again, i don't have the sequence here, but if you search google, you should be able to find one...........
hotwheels of insanemustangs
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Careful - these are easy to break.
No need for more than 18-20 ft-lbs. on the lower intake to the heads. No more than 12 ft-lbs. on the upper intake to the lower intake.
EDIT -- re-reading the original post, I see the question is confusing. Not sure what you're actually asking for. The lower bolts to the heads; the upper bolts to the lower.
smokinit2
22
Miami, Fla.
I'm sorry,the GT40 upper to lower torque specs,thanks.
