Is there a difference in performance between these? I curently have the edelbrock 5.0 performer and a couple guys are telling me to sell it and buy a explorer upper and lower.
You need to let them know that they are well UN-informed
The Performer 5.0 flows just as much and a bit more than the Gt-40...and both can be ported to match.
Performer is just fine for that combination
A Performer flows in the 209-220 CFM range, while the Gt-40 runs in the 205 CFM range.
Ported, they flow very very close...both of them - Explorer and Performer, around 230 cfm for the lower.
CFM is cubic feet per minute.
In other words, it flows plenty for you...
Does any big vendor still sell a complete Gt-40 upper/lower any more, new?
What GT40 intake? Big difference from Explorer/Cobra to Tubular.
Not in stock form. They all use the same lower which is the flow limiter. Jeff Chambers flow test a GT40 and An Explorer intake at Victory Engines on the SAME lower and the GT40 flowed 206cfm and the Explorer flowed 209cfm. Anderson Ford did a dyno test on the GT40/Cobra/Explorer and throughout the entire 2,200-6,600 rpm band on the same test mule there was 2-3 HP difference in any intake at any point.
when switching to a gt40 intake, what gasket set would somebody use. the ones for the explorer or the ones for the cobra? or does it even matter? i'm just curious![]()
enyawix
you need to check out tmoss's site; he's the guru of porting intakes and possible any other aspect when it comes to intakes imo.
Tmoss is the Intake porting guy! I think he may know a little better than you, the complex workings of the ford intake manifolds. Hahaha...i was going to say the same thing. Enyawix you seem to be one of those guys that knows every single word that aftermarket manufacturers put on their part advertisements!Tmoss is the Intake porting guy! I think he may know a little better than you, the complex workings of the ford intake manifolds.
I would love to see you do a home porting job of an upper/lower intake and then flow bench it. I would like to see the flow rate Standard Dev. of all the runners. Then i would like to compare that to Tmoss'. Its not a good think for one cylinder to get more air than another...that leads to swiss cheese pistons!
poster...stick with the performer!
porting is math no more no less.
