  • 1994 - 1995 Specific Tech
gt40or gt40p?
  • Thread starter Thread starter 1995greenstang
  • Start date Start date May 27, 2008
1995greenstang
89
  • May 27, 2008
which head is better? the gt40p or the 3 bar gt40
Zero_chance
1,244
Maricopa, AZ
May 27, 2008
  • May 27, 2008
I believe the Ps actually flow better (google them and youll find plenty of sites with power and flow numbers) though you need a specific P header or else some have had issues with plug wires being melted. Either one is better than stock though.
Stanger007
2,015
Baton Rouge, LA
May 27, 2008
  • May 27, 2008
I'd go with the P if you are going through the trouble of upgrading to a stock head, you'll want to get all the ponies you can!
Wes
fiveoho
1,958
TN
May 27, 2008
  • May 27, 2008
as stated above, i have heard the P's flow better but i dont believe its a huge amount more. i would do gt40s rather than the P's if i already had headers and did not want to buy another set. although i have heard of guys using mac shorties with the P heads and the clearance is there
1995greenstang
89
  • May 27, 2008
thanks guys ya im going have them fully port and polished just wasnt sure which flowed better thanks for the input
Stanger007
2,015
Baton Rouge, LA
May 27, 2008
  • May 27, 2008
If you're going to pay to have them ported and by the time you have the machine shop go through them, springs etc you are getting close to aluminum head range, eh?
I was at your same spot about a year ago. I did the math, I have aluminum heads now.
If you are staying N/A, the aluminum heads are starting to look VERY attractive. If budget is a concern then you are in the wrong hobby. Do it right the first time.
Wes
blksn955.o
3,263
st.louis mo 314
May 27, 2008
  • May 27, 2008
If your going to port them the nonP's can be porter more due to the P's having a water passage that does not allow them to be ported as much. The P's will flow more stock for stock over the non P's.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
M
Gt40p headers
  • Mike3
  • Oct 14, 2025
1994 - 1995 Specific Tech Nov 1, 2025
Blackhawkxx
M
What cam and heads should I run in my stock 302.
  • MadMatt7
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2026
FastDriver
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
