GT40P heads on a flat tappet engine
  • Thread starter Thread starter crimsonclint
  • Start date Start date May 19, 2008
crimsonclint
18
Valdosta, GA
May 19, 2008
  • May 19, 2008
I have a 289 that I'm putting these on and I imagine a few people have these on their classic builds I just don't want to go roller yet. So my question is anyone know a good stud mount style of rocker that would be good for this head. The heads are bare so any suggestions for springs and valves would be appreciated too! The cam is the comp xe262h let me know if ya'll need any more info about the build!! I really appreciate any help...
Btw this is my first post...
D
D.Hearne
11,730
south louisiana
May 19, 2008
  • May 19, 2008
GT40P heads use pedestal rockers, not stud mount. You'll also loose compression with the larger chambers (60cc vs the 289's 54 ccs) Lookin at about a half point drop in the ratio, unless you mill the heads.
crimsonclint
18
Valdosta, GA
May 19, 2008
  • May 19, 2008
Since the heads are bare my machine shop guy is gonna install the stuff for stud mount style rockers. I'm just not sure what size I need, also according to the machine shop since I'm replacing the crank and rods with 302 stuff it will make up *some* compression. I've been looking at comp high energy 3/8 stud 1.6 ratio rockers. ????
bryanvw61
17
CT
May 19, 2008
  • May 19, 2008
I got the comp roller rockers (1431-16) and studs (4504-16), they came with a good reccomendation (http://www.stangpro.com/html/articles/gt40p_files/gt40p1.htm), you just need to get the pushrod length correct. Supposedly (7831-16) are close, I got the ones with the rocker arm kit which I belive to be the same. I'll know for sure when I instal them tomorrow night.
Contact me if you need valve springs. I have a complete set of brand new stock GT40P ones that are supposed to be good for .5" of lift. I went with an xe268h cam so I had to replace them with some TFS sprigns.
That link has more great info for a 302 flat tappet swap.
Only tricky part will be the headers, which is not as tricky as people make it seem.
crimsonclint
18
Valdosta, GA
May 19, 2008
  • May 19, 2008
Thanks for the info bryanvw61...pm sent
bryanvw61
17
CT
May 19, 2008
  • May 19, 2008
pm back at you
D
D.Hearne
11,730
south louisiana
May 19, 2008
  • May 19, 2008
If you're starting from scratch, might as well go to 7/16" studs and rockers of your choice. 1.6's or 1.7's will work, depending on your cam choice and spring bind specs. 7/16" studs cost the same as 3/8" but are stronger. Won't affect rocker prices either, unless you're shopping the extremely low buck selections.
bryanvw61
17
CT
May 21, 2008
  • May 21, 2008
For all those following this post, this valve train combo went together flawlessly last night. Too bad, I'm still a little ways away from cranking it over.
crimsonclint
18
Valdosta, GA
May 21, 2008
  • May 21, 2008
Good I believe I am going to mimic your set up
Ok a bit of an addition to this situation. My '67 will be utilizing this setup, I am curious how much pain it will be to finish out the exhaust after the MAC direct fits(front runner for headers as of post) on a classic. Any x-pipe ideas????
crimsonclint
18
Valdosta, GA
May 21, 2008
#10
  • May 21, 2008
  • #10
Or off road h-pipe?????
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
