  • 1994 - 1995 Specific Tech
gt40p vs thumper
  • Thread starter Thread starter Gumby84
  • Start date Start date Jun 10, 2010
G
Gumby84
24
IN
Jun 10, 2010
  • Jun 10, 2010
which is better budget money spent. i have taken off gt40p top end off of a blown up explorer i got for free. question is should i put money in those heads ie recondition them and porting or should i buy thumper heads. i just want bust bang for buck and have about 700 dollars to spend. thx
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 10, 2010
  • Jun 10, 2010
Sell the 40's
Put that money with the $700
then
Get yourself a GOOD set of heads
Build your combo around a set of heads that will make MORE POWER
than the outdated OEM gt40 stuff
That is a long term NA plan that will make 300 rwhp or a bit better
How about keeping the 40's and continue to add to the $700 for a
blown combo which would take you past the 300 NA combo
Then again ... if going blown ... just sell the 40's and use the
OEM heads
Also ... you could do some juice ... if you are into that kinda thing
Gotta consider all the options ... don't ya know
Grady
RIO5.0
6,892
N.H.
Jun 11, 2010
  • Jun 11, 2010
Case in point... Eddy heads with rockers.... 750.00. Thumper will charge you bout 650.00 to rework your GT40s. Had some Thumper E7s and no complaints here.... its a fine line to stepping up to aluminum for bout the same dinero... good luck choosing...
For Sale Lots of goodies for 5.0 mustang, heads, cams, intake, t5 - Corral.net : Ford Mustang Forums
whitesqual
235
Coeur D'alene, ID
Jun 11, 2010
  • Jun 11, 2010
You could sell your gt40s and with the money from them and the 700 you will be getting close to owning a set of TW's!
95BlueStallion
My assy trans to myself
5,129
3,100
214
Cedar Rapids, Iowa
Jun 12, 2010
  • Jun 12, 2010
The whole iron vs aluminum thing has been beaten to death. If you want to save for a bit longer, sure buy aluminum, but there is nothing wrong with cleaning up some iron heads. You will get a power increase by using them. Send them off to Thumper, and for that $700 they will be practically new heads with upgraded valve springs, seals, and will be ported/polished. Anyone who says you can buy used aluminum heads for under $1k is right, but you still have to figure the cost of sending them off to be checked and possibly have bit of work done to freshening them up too. Enjoy your new score man.
Killercanary
The car that set the bar.
Altoona, PA
Jun 14, 2010
  • Jun 14, 2010
I'm never one to say use the search button, but this has been covered so many times its not funny.
My 2 cents... spend a little money on new valve springs for the GT40P's or sell them and use your $700 to buy new aluminum heads. I wouldn't waste a single dime on ported stock pieces when there are so many benefits to running aluminum aftermarket heads for just a little more coin.
hollywoodstang
1,095
Jun 16, 2010
  • Jun 16, 2010
if these stock gt40p vs Thumper are the only option you are considering,
I would go Thumper, Thumper heads flow almost well as out of the box aluminum heads. i have seen it on a bench! and his porting price is very good.
for most competition porting/valve job, it will cost right around $1000 or more, for what he does and his workmanship, his price are very good.
Personally i never bought anything from thumper, i have considered it but i have seen his heads at local porting service getting new springs put on and his heads flow! I was surprised, For 302 or 306 thumper heads are very ideal.
Good luck
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
