gt40p vs thumper
Gumby84
24
IN
which is better budget money spent. i have taken off gt40p top end off of a blown up explorer i got for free. question is should i put money in those heads ie recondition them and porting or should i buy thumper heads. i just want bust bang for buck and have about 700 dollars to spend. thx
Sell the 40's :)
Put that money with the $700
then
Get yourself a GOOD set of heads :banana:
Build your combo around a set of heads that will make MORE POWER
than the outdated OEM gt40 stuff :nice:
That is a long term NA plan that will make 300 rwhp or a bit better
How about keeping the 40's and continue to add to the $700 for a
blown combo which would take you past the 300 NA combo
Then again ... if going blown ... just sell the 40's and use the
OEM heads :D
Also ... you could do some juice ... if you are into that kinda thing :shrug:
Gotta consider all the options ... don't ya know :D
Grady
The whole iron vs aluminum thing has been beaten to death. If you want to save for a bit longer, sure buy aluminum, but there is nothing wrong with cleaning up some iron heads. You will get a power increase by using them. Send them off to Thumper, and for that $700 they will be practically new heads with upgraded valve springs, seals, and will be ported/polished. Anyone who says you can buy used aluminum heads for under $1k is right, but you still have to figure the cost of sending them off to be checked and possibly have bit of work done to freshening them up too. Enjoy your new score man.
I'm never one to say use the search button, but this has been covered so many times its not funny.
My 2 cents... spend a little money on new valve springs for the GT40P's or sell them and use your $700 to buy new aluminum heads. I wouldn't waste a single dime on ported stock pieces when there are so many benefits to running aluminum aftermarket heads for just a little more coin.
if these stock gt40p vs Thumper are the only option you are considering,
I would go Thumper, Thumper heads flow almost well as out of the box aluminum heads. i have seen it on a bench! and his porting price is very good.
for most competition porting/valve job, it will cost right around $1000 or more, for what he does and his workmanship, his price are very good.
Personally i never bought anything from thumper, i have considered it but i have seen his heads at local porting service getting new springs put on and his heads flow! I was surprised, For 302 or 306 thumper heads are very ideal.
Good luck
