gt40x power increase and Q's ?
Jay5_o
82
calgary, canada
couple of Question's, lost interest in my mustang for last couple years,got into jeep offroading, but gaining interest again and doing a rebuild on 5.0, started refreshining the bottom end with rings and bearings , also ordered gt40x "turbo swirl" heads, e-303 cam, cobra intake manifold, 70mm throttle body.
what kind of hp and tq gains can i expect with this build ? equals to a 100 shot of NOS i hope? :)
will my factory valve covers and bbk shorties work on these gt40x heads ?
If stang runs fine on SD i will leave it other wise i will conver to mass air , what size of injectors should i get with this combo with 100hp shot of laughing gas?
thanks for any help
Jason from :canada:
I have a similar set up with mass air and have no problems, minus the typical Ecam idle but it isn't that bad. I believe you should be able to use your same manifold covers and yes the shorties will work. I have 30lb injectors and probably should have purchased the 24's instead but i am not running nitrous.
