Black Jack: Dragstrip tuning. New records
Post in thread 'Black Jack: No TnT, but installed Zeitronix dual wideband' https://stangnet.com/mustang-forums/threads/884727/post-9410870
So, that was my fastest 1/4 on a 100 shot with an iced intake, which was good for maybe 1mph that day in the 1/8, but was actually a tad slower than earlier in the day than my best 115mph trap speed. I was doing better driving that day than I did after a year without practice at foxtoberfest. I'm happy with the pick up in trap speed, but honestly, it's not that great for what should be a 50hp pickup.
Anyways, the 92.8 in my recent foxtoberfest runs converts to may 117mph in the 1/4, though the ET would not have been an improvement over the 12.02, IMO.
For me, the loop is further back, and also, just an observation, the directions indicate that his bottom part of the loop is inverted, as they call for the bend to push up into the DS tunnel. But anyways, about 4" further bakc, I'd guess is where the T56 wants it to be mounted.
yeah the bottom part actual copys the contour of the pan in that section so his is upside down, A copy of a copy of a copy of the hpm loop so probably made in China now lol. I didn't realize the t56 was that much longer.
you have this in the old 100shot post you linked, "Edit: Note to self: This was run on the 125 fuel pill with the 100 n2o pill"
the jetting I can find for the kit you listed would put that at 46/34 where it calls for a 46/30 on there "100" shot,
there 125 is 54/34 for that kit no other jetting listed above it. Kit should have come with. 026" .030" .034" .040" .046 ".054
Only kits I can find listing a .067 as a 150 shot Is using a .038 fuel jet and is there high output wet kits that uses better individual selonids not in a control box. Edelbrock groups has made a mess of that brand and many others though so info isn't the easiest to find and may not be current, pulled the jetting from Jegs old PDF instructions on it
This run was .067 on the nitrous side with a .032 fuel. thats a decent jump in rasing the nitrous and lowering the fuel from the "100" shot, the 100 shots fuel jet was larger than what your currently using from your note in the post. I expect the 54 jet is about the limits those selonids will flow and your 100 shot jetting pass should have been pretty rich, you might want to try there 125 shot jetting with .054/ .034, and if you have all the listed jets it came with plus a .032 you can test it with the .032 and .030 on the fuel side, I bet it picks up the more fuel jet you drop. Your all ready using a smaller fuel jet with a much larger .067 which will flow enough for about 170hp gain when its the limiting factor. Just bring fresh plugs and read the timing strap and fuel ring after a pass. its a hassle but only real way you can dial nitrous in, and you would be suprised how much you can pick up doing so. .052 nitrous jet is almost always good for at least 10mph gain over na trap speed in the 1/4 once its dialed in, in my experience on these types of combos. So there "125" shot cleaned up should be able to better the current jetting your using and should be within the limits of the selonids.
Good info. I'll keep that in mind if I run into anything with 'em. Don't suppose you have the part numbers for the 3' leads and whatever you used for a timer? I'm happy to wait until there's a verified problem, but it'll put my mind at ease that there's already a known solution if I do run into that, too.
The shorter leads are available at Zeitronix.com---> order---> scroll to bottom where seperate cables are listed---> select drop down option for your cable length..(3',10', 20')
As for the wideband power up delay, my engine management looks for RPM and won't send power to the wideband controllers until RPM exceeds about 250 RPM. So i don't get any power to the wideband controller with just the key on. I dont recall what you are using for tuning. Maybe you have an extra configurable output to use that could be tied to RPM signal, or oil pressure. If not i did have a really slick oil preasure switched setup before I went to a stand alone. The info and parts #s are in post #11. I used a pressure safety switch to ground switch the wideband relay.
https://stangnet.com/mustang-forums...motiv8-engine-management.928171/#post-9415452
  • Useful
Reactions: FastDriver
After driving around with the dual wideband for the last couple of days, I've discovered that the driver's side bank, which I've been tuning from, consistently runs about 0.3–0.5 AFR richer than the passenger side. The difference is most noticeable under load and at WOT, and much smaller at cruise and idle, presumably because the ECU's fuel trims help even things out.
I'd deliberately tuned the NA WOT AFR to a conservative 12.5–12.6 on the driver's side, but now I see the passenger side is closer to 13.0, which I'm comfortable with naturally aspirated. I'm glad I erred on the rich side.
I haven't made another WOT nitrous pull since installing the dual wideband, though, and our discussion has made me realize I may have been running with less safety margin than I thought.
You're right that I was using jet charts from other kits to estimate my starting point. I originally tried the .038 fuel jet with the .067 nitrous jet, but AFRs were in the 10s, so I progressively leaned it down to .032.
Given what I've learned about the bank-to-bank difference, I'm going back to the .034 fuel jet before making another nitrous pass. I've already run that combination without apparent issues, and it should give me a little more margin while I see what the passenger bank is doing. I'd still like to target around 11.5:1 and get the fueling sorted out before experimenting with timing.
There's another test-and-tune this Friday that I'm planning to attend. I don't have any other work planned on the car, so hopefully I'll get some useful data to share.
This is what Monte Smith always suggested, RIP. Just to show I'm not suggesting anything wild, though the majority of ppl with bolt nitrous kits run them way richer than needed, as thats how there jetted when sold. third reply down . https://www.yellowbullet.com/thread...1239138/?utm_source=google&utm_medium=organic.
"As a general rule........wherever the motor makes best power N/A is also where it will make best power on the hose. It's the same motor and the same parts, it is just making more power, more efficiently on the nitrous. No reason that the A/F would need to be much if any different.
On our 738 with 4 kits........we run to a target number of 12.9.........that's where it runs the best. Your mileage may vary.........LOL!!!
Monte".
Your .067, jet even if extremely rich, isn't showing the gains of what a .067 jet can flow, my main thought is the zex selonids can't flow the full potential of that jet. most efi single nozzle kits use a .062 as there "150 hp jet" The gains you've all ready seen as shown by old dyno numbers and mph at the track can be achieved and bettered on the 54 nitrous jet which is what the kit came with. I honestly would start with that if you want reliable data to tune off of with what you currently have. Afr gauges are nice for tracking and tuning, but plugs don't lie. Nitrous isn't forced induction, it doesnt needs a richer afr for a cooling affect at all, its on/off after a pass.
Test n Tune at Rockingham is cancelled for today. Boo! Well, tomorrow, is Cars n Coffee n Morrisville, which usually brings ~2k cars, with either Black Jack, or Father Time.
@AeroCoupe
Didnt wanna side track @Mustang5L5 's thread, but in reply to your comment:
Can you swap the wide band sensors from left to right to make sure it’s just not a sensor deviation?
Good point. Entirely possible. I've also considered swapping injectors from bank to bank, the narrow band sensors that the trims rely on, eventually maybe ignition stuff, too, until I usolate the problem. I will also, before anything, see if the trims are pulling fuel from the right bank or adding it to the left.
One thing is for sure, I'd like to understand it more before continuing with the 150 shots. This could potentially be a single cylinder with a defective injector spraying a lot leaner.
So, I had a nice time at Morrisville, NC Cars n Coffee, this morning. I was dumb on the way out. Without thinking about it, I armed the nitrous on 87 octane !?! and raced this Challenger from a highway roll through 3rd and 4th gear:
I put a few cars on him and let out.
We complimented each other on the cars. I told him I sprayed. He said he had installed BBK headers on this 6.4L last night, but stock cam and I guess otherwise stock. It was an auto. Can anyone tell me what year and what to expect from one of these in terms of quarter mile trap speed?
Black Jack seems no worse for the wear, but I wont do it again, and was just thinking I ought to put a little sign on the tank to remind myself to ensure it's 93 octane. Another guy actually recommended a 1 gal cell with its own fuel pump in the engine bay for race gas to spray with the nitrous automatically, recently. Interesting idea.
Anyways, on the way home, I took a vid of the differences in AFR bank to bank that I'm seeing at WOT but not at cruise:
View: https://youtu.be/bxA78iXvHk0?is=7GBb4CD4vkCmKBsn
Some other pics from the show are attached.
Took Black Jack to the track tonight for some tuning and ended up with two new personal bests ET & mph: 11.91 @ 115.38 mph and, on a different pass, 117.99 mph!
And, I think the 1.80 60' is a best, too, finally eclipsing the 1.83 I did all those years ago with 4.10s and a T5 on stock sized radials and a completely different launch strategy. The terrible gearing just needed 150-ish more torques.
Anyways, not bad for my full-weight, daily-driven '91 LX with a stock-bottom-end 302, GT40X heads, E303 cam, T56, and ZEX wet nitrous!
Spent most of the evening running naturally aspirated, experimenting with WOT timing. Tried 31°, 32°, and 33°, and ultimately settled on 31°. It didn't give up any MPH compared with 32°, and adding timing didn't seem to help. I also made a small enrichment adjustment in the ECU to get the right bank where I wanted it. On nitrous, I reduced the MSD retard from 6° to 5°, preserving the same effective 26° timing I'd previously been running. It ran a best NA trap speed of 106.43, and did it to the hundredth both at 32 & 31* total. So, from that to the best N2O trap speed, it picked up 11.56 mph. So, the Zex may be worth ~135hp at the crank, before I continue to tweak timing.
Rednotch, thank-you. You really got my attention about my nitrous fueling, and I'm glad you did. On my first 150-shot pass, I saw 12.6 AFR on the passenger bank, which scared the hell out of me. I don't know how much of that was the difference between my old Innovate and the new Zeitronix, bank-to-bank variation, or bottle pressure, but I had also seen AFRs in the 12s on the other bank. Whatever the explanation, it was right to make me take a closer look, and I'm grateful I didn't blow my stuff up. I expected to be running a sub 12 AFR.
That first pass, with .067 nitrous/.032 fuel jets, went 12.51 @ 117.99 mph, despite completely blowing the tires off and running a miserable 2.21 sixty-foot.
I decided to go rich and work backward, so I installed the .038 fuel jet. AFR dropped into the 10s and 11s, but power delivery became erratic, especially in third and fourth. I suspect it was so rich that I was blowing out the spark.
Next came the .036 fuel jet. The breakup improved somewhat, but I was still seeing low-10 AFRs on both banks. I also discovered my bottle pressure had fallen to about 850 psi, which may have contributed to the rich readings and declining trap speeds.
Meanwhile, I was experimenting with the two-step. At 5,500 RPM, the tires went up in smoke. At 4,500, they still spun. Finally, I tried 4,000 RPM, and that was the breakthrough. The car hooked, didn't bog, and went 1.808 in the sixty-foot, carrying it to an 11.91 @ 115.38 mph!
My previous best was 12.029 @ 114.45, so finally breaking into the 11s feels pretty damn good.
Next time, I'm going to get bottle pressure back where it belongs, see what that does to the AFR, and work on jetting from there. The .034 fuel jet may be next, depending on the results. I'm convinced there's considerable MPH being left on the table with the current rich condition and breakup.
The exciting part is that I've now demonstrated both an 11.91 ET and nearly 118 mph, just not on the same pass. If I can put those together, I think 11.60s are within reach.
And with the new engine I'm building for Black Jack, maybe there's even a 10-second pass in its future. We'll see!
For now, I'm thrilled. I've been working toward this for a long time, and the old stock-bottom-end 302 is still getting it done.
@85GTStangGuy... I'm getting that seat time I needed. Better get the nitrous ready for next year!
How was the ambient temperature throughout your trials? If it drops during the evening it can add another factor to the equations..
A while back my son and I took the 96 Vette to the track. Throughout the evening it did consistently low 12’s. Then we parked it for about an hour. My son said, “one more before we go home”. The temp had dropped since parking the car last and obviously it had time to cool down. Furthermore by that time in the evening the staging lanes were almost empty. He started the car and pretty much drove right up to the line without any waiting. It went 11.88 @110
Correction: low 13’s all night then a 12.88 @ 110
@JD1964 Agreed. See tables below.
So, these LLMs are just changing the way we do things. I have never been the type to keep copious notes, but now that I can just talk to ChatGPT from run to run, it's a lot easier to do. So, I used it this morning to build the details from last night into a couple tables showing the facts if each run & the baseline plus adjustments I made from run to run. It gives a better idea of what we do when we go to a test n tune:
* Ignore the reaction times. Chat GPT gooberd those up.
Black Jack — November 13, 2026​
Baseline and Adjustments from Run to Run
Note:
The two-step currently operates only when the nitrous system is activated. All naturally aspirated launches are controlled entirely through accelerator-pedal finesse and clutch engagement. I'm considering modifying the electronics to make the two-step available for NA launches in the future.
Run #1 — NA Baseline​
  • 93 octane, A9L/QuarterHorse 93 tune, nitrous OFF
  • WOT timing: Stock A9L +6° advance = 32° total at high RPM
  • FN303 WOT fuel multiplier: 1.000 through 5,400 RPM; 1.031 at 5,500 RPM and above
  • FN303 note: This multiplies the commanded AFR, not injector pulse width. Values greater than 1.000 command a leaner mixture; values below 1.000 command a richer mixture.
  • Nitto drag radials: 20 psi
  • Front Koni: Rebound full loose; compression 2/12 clicks
  • Rear Koni: Rebound 0.75 turn from loose; compression 2/12 clicks
  • Full street weight, trunk gear, approximately 3/4 tank — about 100 lb heavier than my usual dragstrip configuration. Focused on tuning, not setting records.
Run #2 — NA​
  • Lowered both drag radials to 19 psi after observing incomplete tread contact near the outside edge of the passenger-side tire.
  • Raised launch RPM to approximately 6,000.
Run #3 — NA​
  • WOT timing: 32° → 33° (+1°)
  • Reduced FN303 multipliers to command approximately 2% richer AFR, accounting for the passenger bank running slightly leaner than the driver side.
  • More aggressive clutch engagement; powershifted.
Run #4 — NA​
  • WOT timing: 33° → 31° (−2°)
  • Tried more aggressive clutch engagement.
Run #5 — NA​
  • Stopped using the shift light and shifted by tachometer at approximately 6,000 RPM.
  • Engine seemed to fall off at higher RPM, possibly valve float. However, I'm not convinced the shift light is activating at the RPM stamped on the pill. By ear, it sounded like the engine was exceeding 6,000 RPM before the light activated.
  • Considering a 5,600 RPM pill for future testing.
Run #6 — 150-Shot Nitrous​
  • Activated nitrous: .067 nitrous / .032 fuel jets
  • MSD retard: 6° → 5°, maintaining nominal 26° total timing under nitrous
  • Two-step set to 5,500 RPM
Run #7 — 150-Shot Nitrous​
  • Fuel jet: .032 → .038
  • Two-step: 5,500 → 4,500 RPM
Run #8 — 150-Shot Nitrous​
  • Fuel jet: .038 → .036
  • Two-step: 4,500 → 4,000 RPM
Reactions: Blackhawkxx
Uh.. Yes. I thoroughly enjoy doing this stuff, and posting to you guys. I also like kinda use the buuld threads as a way to track things. At this point, when I forget something, ChatGPT can scrub my thread and tell me everything I've ever posted about the car... pretty handy! I kinda wish I was more interested in doing youtube videos instead of blogging here, because some of them boys are winning shows & getting big money for the foxbody work due, in my opinion, to their popularity.
