GT40Y combo question
My combo of > GT40Y heads, Cobra I/T, lower cleaned up, 65mm tb, svo1.6rr, 1 5/8 shorties,2 1/2 bbk catted h & flows,pullies, efan, with this set up made 270rwhp/305rwtrq, can I squeeze another 10rwhp out of this set up by going to 1.7rr, the heads are low mile heads. any other suggestions would be appreciated.
You didn't mention having a larger than stock throttle body or a larger than stock MAF sensor. If you are looking to pick up 10hp and you don't already have these things, I would look there.
First off what camshaft, I am assuming stock? You will sacrafice a little low end grunt but there is another 10 rwhp in the 1.7 rockers and an intake spacer of 1 inch. You will think you actually lost power cause it will make it a bit soft down low, but you will notice the difference up top. You will problably pick up another 500 usable revs on the high end. I would also ditch the catted H if possible for an offroad, and look into a timing bump to 14 degrees.
Get a custom cam, have the heads valve jobbed, bowls cleaned up and milled and you will be able to squeeze 300rwhp out of that setup (with a good maf too if you don't already have one).
Keep the 1.6's, because most cams are ground to use them.
I know this is not the anwser you were looking for, so to answer the original question, 1.7's aren't worth the trouble, there is definetely NOT 10rwhp in them.
