Guages???
droptopsnake01
263
I want to get two pillar guages for my car. It would be more for looks but, are their any guages that would actually be helpful on a n/a car?
Im going to get the air/fuel guage, but I need one more.
I also am planning putting nitrous back on my car so that might help out also.
I would get the water temp & oil pressure. The Autometer air fuel gauge that hooks into the stock 02 sensors does not give good readings, it bounces around alot cause it is using a narrow band oxygen sensor & not a wide band 02.
What 94CobraPace said.
If you want a DECENT A/F gauge, you might as well run a wideband. Refer to the following thread over in "4.6" for more info about a wideband install:
http://forums.stangnet.com/showthread.php?t=481847
Additionally, oil pressure (since the factory/dash gauge is just an open/close 8 psi switch = useless) is an excellent aftermarket gauge choice. Water temp is also a good idea for NA vehicles...but that may not be as important to you since you are planning on running nitrous in the future. Just some food for thought.
Here's a few helpful resources:
http://www.fnsweet.com/garage/gauge/index.shtml (A-pillar/gauge "how-to")
http://www.corral.net/forums/showthread.php?t=232504 (Cosby's install w/ pics - oil pressure/water temp)
http://www.corral.net/forums/showthread.php?t=157928 (oil pressure sender install)
:cheers:
From my research, they do not make the pillar pod for convertibles, I am looking for one now, in 2 or 3. They all say "not for convertible". Best I can see doing is getting the 2 pod that bolts to the existing piller, a add on.
Other options, the gauge bezel with 2 gauges openings. Since you have a 01, not clock pod on the dash, unless you cut a hole in the dash?
