Im just about done with my new engine. Its a 306 with the the trick flow setup, 9.5 compression, 75mm t/b, and 30 lb injectors. Nothin to fancy. Befor I get any flames about why I went with 30lbers and a 75 t/b, its because in a year or so Im hoping to put a supercharger on it. Just preparing ahead of time. While I was in there I went ahead and put a 3g alt on and a electric fan. If I new how to post pics on here I would. Anyways It will be done in about 2 weeks or so. I just waiting for my dcc fan controler. As soon as Im done Im taking it to get dyno tuned. My question is, It looks like most guys on here are getting about 300+ rwh from a combo like this. I live in Colorado Springs which is at about 6,000+ feet. Im just wonding what you guys think I should be getting at this altitude so Im not to disapointed when I see the numbers. Does about 250 rwh sound about right. God that just sucks, lol.
You will struggle a bit with the big injectors, but I think your 250 rwhp is a good guess. The blower should give you another 100 easily. your dyno guy will be able to make the correction to tell you what your sea level #s would be. Dont concentrate on your dyno numbers too much, if it pulls like you think it should, your good to go.
hell the kit gives you around 290.. and you see around a 5 hp gain from boring it out to a 306.. you definately need smaller injectors.. and a more accustomed cam would wake it up more than it will.. i'd run with a Crane 2021 cam or a AFM cam
