Shaun1212
Trick flow combo
Tfs combo says this will give you 360. If you put a bigger cam in there you might get close to 400 if your lucky.
Manufacturer's Part Number TFS-K514-360-350
Part Type Cylinder Head Combos
Product Line Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L
Summit Racing Part Number TFS-K514-360-350
Camshaft Included Yes
Intake Manifold Included Yes
Fuel Delivery Style Fuel injected
Intake Material Aluminum
Intake Finish Silver powdercoated
Intake Style Electronic fuel injection
Intake Manifold Model (descriptive) Trick Flow Track Heat
Timing Chain and Gears Included Yes
Lifters Included No
Gaskets Included Yes
Cylinder Head Style Assembled
Cylinder Head Material Aluminum
Cylinder Head Finish Natural
Combustion Chamber Volume (cc) 61
CNC-Machined Combustion Chamber No
Combustion Chamber Style Heart
Intake Runner Volume (cc) 170cc
Exhaust Runner Volume (cc) 66cc
CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner No
Intake Port Location Standard
Exhaust Port Shape Square
Exhaust Port Location Standard
Intake Valves Included Yes
Intake Valve Diameter (in) 2.020 in.
Exhaust Valves Included Yes
Exhaust Valve Diameter (in) 1.600 in.
Intake Valve Angle 15
Exhaust Valve Angle 17
Valve Springs Included Yes
Outside Diameter of Outer Spring (in) 1.460 in.
Damper Spring Included Yes
Number of Springs Per Valve Dual
Retainers Included Yes
Retainer Material Chromemoly steel
Locks Included Yes
Lock Style 7 degree
Valve Stem Seals Included Yes
Valve Stem Seal Style Positive stop
Valve Stem Seal Material Viton® fluoroelastomer
Rocker Arms Included Yes
Rocker Arm Style Full roller
Rocker Arm Studs Included Yes
Rocker Arm Nuts Included Yes
Rocker Arm Nut Thread Size 3/8-24 in.
Guideplates Included Yes
Guideplate Pushrod Size 5/16 in.
Pushrods Included Yes
Valve Covers Included Yes
Valve Cover Material Die-cast aluminum
Valve Cover Finish Silver powdercoated
Valve Cover Mounting Style Perimeter bolt
Accessory Bolt Holes Drilled Yes
Valve Guides Included Yes
Valve Guide Material Manganese bronze
Valve Seats Machined Yes
Valve Seat Machine Style 3-angle
Valve Seat Material Tungsten
Steam Holes Drilled No
Oiling Style Through pushrod
Machined for O-Ring No
Heat Crossover No
Cylinder Head Bolts Included Yes
Quantity Sold as a kit.
Notes This kit will not work on 1994-95 Ford Mustangs.
Lifters Included No
Locks Included Yes
Lock Style 7 degree
Heat Crossover No
