guesstimations? what do you think im running
91foxbod50
486
I just installed the fallowing w.o time to dyno the car.
Bbk longtube headers, o.r h pipe mac catback
Msd 6 al ign
Adj fpr
Cobra tubular upper and lower intake
24 pound injectors
Novi 1000 supercharger 6 psi fms
What should I be looking at? I'm very impressed with the boltons.
The heads cam and gears are stock.
Posted via Mobile Device
He is probably a really good driver first off, and secondly, running slicks and knowing how to launch on them is a huge plus. With your intake and exhaust you might be up more like 325 rwhp, just depends on the tune and overall condition of your shortblock. I would probably stick with 3.55's since you are blown, otherwise 3.73's or up may be a little too steep. You will run through first like it isnt there, and if you do future engine mods you will wish you kept your gears a little lower.
save up a little more cash and try this=AFR 165s and a custom cam and u will have enough HP to split your block:D
BTW i have the same BBK longtubes OR H-Pipe mac catback...... how do u like the sound?
it sounds great, it has a lot of tone in comparison to the shortys and magnaflow I was running. I think I'm going to go with some trickflows. I've heard of a place that rebowls and ports springs them for you for cheaper than afr heads.
Msd 6 al ign
Adj fpr
24 pound injectors
I'd say 300-310rwhp if correctly tuned. Get rid of the stock heads if you want to make real power.
up the boost
:stupid:
I'd guess with that setup tuned right 330 to the tires isnt a stretch. These numbers are with me thinking your running 10psi
what exactly is re-bowling an how do you port a spring? If you go with TFS, get the fast as cast head, its modeled after thier CNC twised wedge head for like 1500 bucks i think
:stupid:
My typo they widen the bowls, and upgrade the springs. Posted via Mobile Device
Oh, I've been high 12s on Falken Street Radials, mid 12s with a real tire. :D
A set of Explorer heads, cam and intake will net 300 to the tire when done right.
