  • SN95 4.6L Mustang Tech
gutting cats??
  • Thread starter Thread starter rice slayer'
  • Start date Start date Aug 14, 2004
rice slayer'
87
everywhere
Aug 14, 2004
  • Aug 14, 2004
if you gut your cats will it throw you chk. eng. light on??. or would you better of just running new pipe with mil eliminators??
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Aug 14, 2004
  • Aug 14, 2004
yes it will put the check engine light on. The sensors detect not whether or not the cats are ON, but whether or not they are working... gutted cats don't do there job (they dont "work" essentially) which is picked up by the rear 02 sensors.
You're BEST off (if that makes sense) by running gutted cats and MIL eliminators for normal street use (minus inspection of course, unless you're lucky and only have to pass visual, not the butt-sniffer test )
Why? Because gutted cats will protect you from the all too common "cop on his knees with flashlight, checking for cats because he's pissed off your car is too loud", where as, striaght pipes ("race pipes") will just get you into trouble (most) of the time.
Regardless of what you choose, MILs will be required if you have, for any reason, non functioning, or non existent cats, or else you can stare at the check engine light (which isnt good, becuase if something really goes wrong, you wont know).
JBushman73
172
Roanoke, VA
Aug 14, 2004
  • Aug 14, 2004
On my 98 4.6
-Cut 4 of the 6 cats off. No check engine light. Had the MIL's and never needed them.
On my 04 4.6-Cut 2 of the 4 cats off. No check engine light.
Just an FYI.
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Aug 14, 2004
  • Aug 14, 2004
what do you mean you "cut them off"... you mean you removed the stock mid pipe, cut the cats out, and sectioned and welded in straight pipe to the STOCK? or did you just buy an aftermarket catted H/X pipe w/ hiflow cats??
JBushman73
172
Roanoke, VA
Aug 14, 2004
  • Aug 14, 2004
I didn't just cut them off and leave it that way.
I had the shop put straight pipe in the place of the old cats. It wasn't necessary to take the mid pipe off.....Kept the cats in the basement in case I ever needed them down the road.
dmarco_4u
194
  • Aug 14, 2004
get the bigest screw driver and a hammer and take all your frustration on those cats , the drivers side of the pipe was easy as hell to remove, but the passengers side is a whole complete different story.
it will take you 30-50 minutes to gut the drivers side cat.
the drivers side will take you 2-3 hours since it has that bent.
jbushman is right your check engine light wont come on if you only gut the two pre cats. if you planning to gut all 4 good luck.
if you have state inspections i would recommend you buy a used stock pipe and gutt that one and save yours until inspection. stock pipes go for 50-60 bucks at ebay. if you need to buy a new one from ford it will cost you $2000 yes $2000.
you will get a big sound difference and you will love it since it didnt cost you a thing. if you want some tips go to my page 2 on my cardomain site it has the tools i used. and some tips..
rice slayer'
87
everywhere
Aug 14, 2004
  • Aug 14, 2004
thanks man , today im headed down to muffler shop, gonna ask if they can just cut the two cats off in the front for me and then weld in a piece of pipe to replace it,... sound differnce???
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
