H/C/I done!!
Looking at that third picture it looks like you forgot to drain the coolant out before you took the heads off. I hope you have changed the oil, it would def. not be good to have coolant in the oil.
Also how do you like the Typhoon intake I have been told it is more of an upper RPM intake, did you lose any low end with it???
drgn5.0 said:
you try adjusting your idle screw any?
i set it as far back as i could get it at the time.. the tps is set at something like 2.53volts, which i know is way to high but its the best i could get it to at the time.. i'll play around with it again later though
5 Liter Mustang said:
if you dont mind me asking, how much did the whole ordeal set you back?
i'm not sure on the exact price but i think with everything that i put on the total is probly alittle under 4 grand, maybe closer to 3,500
bgjohnson said:
how do you like your typhoon intake, i bought one and love it so far only I went with trick flow stg1 cam and powerheads and man it pulls pretty sweet at about 4k, and hey does your car hate it when it's warmed up, you go into a store then come back and start it and it wants to surge itself untill it's driven about a block. what do yo have your fuel pressure set at?
i love the intake.. it definatly suffers in the low rpms, but i wasnt lookingto build a torque monster with this car.. and yes it does do the same thing, it surges pretty bad for the first 5 minutes or so and then it calms down.. as for the fuel pressure i'm not sure what its at.. the guage isnt working right now so it set at whatever will keep te car running
i did drain the coolent but i guess that was just some left over in the bock.. i got it al out by blowing it out with compressed air, then i used as shop vac and rags to clean everything up
Bigstang1 said:
BGjohnson, dont mean to steal the thread but how is ur car on power and tourqe before 4k? Is it like decent or almost annoying that there isnt enough? I was thinking about that cam for one of my many combos that i dream up when im bored in school lol
well I wouldn't call it disappointing, it's just about the same as it was before, I can still lug it at 1600RPMs and accelerate up a hill, but when you floor it you don't get the awsome pushback, but when it hits about 4K it's like you hit the Nitrous or somthing it just wants to keep pulling. but everything I bought is for high RPM use, 1.9/1.6 valves on heads, typhoon intake,but the cam can be used for torque applications too. I used to dream up what I wanted to put into my car too when i was in school, that's why it took me so long to come up with the money because I wanted to do it right. I'd been researching since about 2002 so I planned things out pretty good, but dreaming is still fun. I'm now dreaming of 10 PSI and a vortech :D
