H/C/I No Start
  • Thread starter Thread starter Strype
  • Start date Start date Oct 17, 2009
  • 3
First Prev 3 of 3
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 19, 2009
#41
  • Oct 19, 2009
  • #41
Thats called a vacuum leak. LOL
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 19, 2009
#42
  • Oct 19, 2009
  • #42
Yea I know and laugh at this-
My buddy comes over on Saturday. The valve covers are for a truck. One of the openings is dead under the throttle bracket. He is looking that way while I am pouring over the motor and says to me, "You need to get a breather for this- why is there no PCV valve?"
Quick Strype thinking I know that on old cars (carbed) the valve cover opening is used for PCV. So I said "I don't need that, don't worry about it man." He scratches his head and says "Whatever"
Then today my neighbor brings his battery charger over and is assisting me on timing and fuel pressure. He says as I am cranking "I smell PCV". This guy owned his own mechanic shop. I completely ignored him and we kept going. Finally after 30-45 minutes he's had enough. He says "Jon this sounds like vacuum" and he starts probing. Sure enough he says, "What is this connected to?"
I look at him like he's stupid but being nice I look back to see and sure enough the PCV valve is dangling from the back of the upper plenum.
So anyway it sounds smooth mechanically. I need someone to time it because I can't keep it running long enough to find the sweet spot (pun intended) with the timing light. There probably is a fuel leak. There is probably a rocker loose or tight, but the fact of the matter is that the end is in sight.
I will post a part 2 if I can't get this one figured out.
I have been cured of my thick headedness. Turns out I'm not the smartest guy on the block.
L
Lawbreaker5.0
543
Texas
Oct 19, 2009
#43
  • Oct 19, 2009
  • #43
so the main prob was the pcv hose wasn't connected? thats pretty funny but hey it happens.
does the timing light have and advance knob on the back part of it? if so make sure you set it to zero or the timing will bounce all over the place
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 20, 2009
#44
  • Oct 20, 2009
  • #44
Yea its got one. Right now its sitting WAAAY advanced so I'm gonna wait for some help. I can't keep it running long enough to time it.
strtrcr50
Previously from Dirty Jerzey exit 7a
Oct 20, 2009
#45
  • Oct 20, 2009
  • #45
It SHOULD run at -10 to +10 with the spout in relatively easily. Won't run right, but should maintain an idle so you can set the timing.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 20, 2009
#46
  • Oct 20, 2009
  • #46
Yea I gotta get the dizzy right
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 22, 2009
#47
  • Oct 22, 2009
  • #47
Still can't keep it running long enough to change the timing. It makes pops and stumbles when it gets down to 500 rpm, which it should not be at. I checked the vacuum lines, the fuel pressure is running about 40-45 with the vacuum line off. It was idling low and popping and stumbling bad when I tried to take the timing light to it and the light wouldn't work, but it has worked before.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Nov 9, 2009
#48
  • Nov 9, 2009
  • #48
Resolved...
http://www.stangnet.com/mustang-forums/798891-hci-no-start-part-2-a-2.html
Strype said:
Okay here's a rundown of all the problems I ran into...
A) Fuel pressure loss- The BBK SSI intake was to blame. The tube inbetween the fuel rails was leaking.
B) Vacuum Leak- We had accidentally pulled the PCV valve out.
C) Spark plugs- The GT40X heads take 3924 (I think) Autolites.
D) Valve train- The rockers must be shimmed exactly as shown here: http://www.stangnet.com/mustang-forums/785764-cam-timing-question.html#post7909781
E) Timing- The black "reluctor" has to be pointed at 12:00. The rotor should be just behind it. The number 1 plug on the cap must be over the rotor or just after. That plug actually sits just over the black magnetic pickup (reluctor I think).
F) Fuel in the Oil- After many attempted starts the unburned fuel was just pooling inside the combustion chamber and you could tell from the plugs. Some were black and some were clean but they were all drenched. It was obviously washing out the cylinders.
  • 3
First Prev 3 of 3
  • dan50
  • Jul 18, 2026
dan50
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
