2002BLGT said:I have a B cam ($189), GT40Y303 heads ($719), Typhoon intake ($280) bucks , stock shorty headers , gutted factory Hpipe , flowmaster cat back , car made 245 rwhp , 274rwtq , total investment with gaskets and all , little over $1200 bucks , dont think you can buy a blower for that and at around $1600 bucks I dont see a novi 1000 or powerdyne 6psi kit beating those numbers by much on a bone stock car .........and keep in mind the trickflow stage one cam is better than the B cam , and its 50 bucks cheaper
Andres2882 said:But would putting on a blower be safe for a 12+ year old car with 100k+ miles on it? Isn't that a bit liking pulling the pin out of the grenade?
jrod92 said:What does H/C/I stand for? High Compression Intake?
2000xp8 said:It likely won't be safe, as i said earlier i see it all the time, the boost will blow out gaskets all over the place. Your intake gaskets will be gone in weeks. If you are fixing them yourself for free that's one thing, if you have to pay to have it done that's another.
QDhorse, i see what you are saying.
If it was between a mild h/c/i combo and a supercharger i'd take the supercharger.
IMO there is no point anymore in a mild h/c/i setup, at the track on slicks they are ok, but you'll get your'e butt whooped on the street by every ls1, evo, and srt neon.
I also don't see the point in the SC or A-trim, get the S so you don't need to upgrade later.
If you go for the H/c/i go all out or close to it, like edelbrock, afr,canfields, or tw's.
I'm not down with ported E7's, ported stock intakes, gt40 irons or p heads.
Doing H/c/i work twice is nuts, there's too many gaskets and misc crap that has to be bought twice.
So in conclusion, my final opionion is:
An all out h/c/i combo, and if not, an S trim. To me there is no other options.
mustangdaren said:S- trim
680 max horsepower
1000 cfm
20psi max
50,000 rpm max
72% adiabatic eff.
SC-trim
680 max horsepower
1000 cfm
20 psi max
53,000 rpm max
75% adiabatic eff.
IntenseBlue said:I'm not positive on this, but I think they gave the wrong stats on the SC trim. I think it's like the Novi 1000. While an S trim is like a Novi 1200. The S trim and Novi 1200 have the same boost/horsepower stats, but the 1000 is 500horse max.
IntenseBlue said:What's the difference then? Can you put it in realworld terms or was that just a copy/paste effect?
IntenseBlue said:The Novi 2000 is alot better than the S-trim. It's up there with the D1 and T-trim.
I didn't want to know the difference between the kits. I wanted to know the difference between the head units.
90mustangGT said:A proper H/C/I would make more power but would most likley effect the gas milege and drivability negativly. A S/C wouldn't do much to gas milege, emmisions, or drivability but would add a considerable amount of power. Plus, do a S/C then you can later do a H/C/I that better matches a S/C setup.
