Need some estimates as to what you I can expect for power at the rear wheels with my set up. Found a dyno shop in Connecticut that does 3 pulls for $75.00. Here's the list.
306 bored .030 over froms stock, ported gt-40 y303 aluminum heads with 10:1 compression, CompCams .533 intake lift with 215* Duration & .544 exhaust lift with 220* Duration. Ported/Polished Cobra Upper/Lower intake.
Jacobs 5.0 Ultra Team ignition system. C&L 73MM MAF with 24lb/hr injectors.
Tremec TKO 600 tranny with 3.55 rear gears and aluminum driveshaft.
My engine builder and I were aiming for 345-350 HP at the crank and about 300 at the wheels due to loss of 35-40 HP through drive train. Any thoughts on the rear wheel torque as well would be great!
Thanks
Thanks
