H-pipe Install
nullsetzero
I've been out of the game for quite some time... had a heavily modded 87LX about 10 years ago and somehow all my tools walked away.
Just bought a 1990 Notch and will be installing a used h-pipe asap. My question is...
Does anyone have a tools list of what socket sizes, wrench sizes, universal joints, extensions etc I'll need to install the h-pipe, O2 Sensors?
I know this is basic stuff, but I'm building my toolbox back up from what it used to be and I want to get this show on the road!
Thanks
Mintsick
589
39
68
West Lafayette, IN
Hard to say, you did not mention whether or not the exhaust is completely stock at this point or not. A typical metric/standard mix of sockets with a 3/8" ratchet, mix of wrenches, and a few extensions should serve you well though I'd say.
ReefBlueHatch
682
96
39
Central KY
I know the 02's are 7/8" because I just changed mine. I would highly recommend a 02 socket from the parts store for under $10. I couldn't break mine free with just a wrench and it wanted to round off, but the socket bit great and allowed me to use long handled ratchet for leverage.
89stang1
Stroked and Juiced
730
234
74
nj
I know the 02's are 7/8" because I just changed mine. I would highly recommend a 02 socket from the parts store for under $10. I could break mine free with just a wrench and it wanted to round off, but the socket bit great and allowed me to use long handled ratchet for leverage.
I did my 02s last year had to use a bar over my ratchet and i sprayed wd on it a couple times the day before to get 02s off. 2 weeks ago i installed a new off road h pipe on my car what a pita, next time i find a lift to do it!. After the first nite on my back on garage floor i got the old one off, the next nite i put new h pipe up on the hangers and noticed the lineup to my headers were not even close. So after cutting the two hanger wires off h pipe i installed it total of 3 1/2 hours on my back came out good but never again without lift!
Gearbanger 101
Straight Outta Locash
9,457
1,378
234
Ontario, Canada
I needed heat to get my O2's out. Took the threads out with them unfortunately. Just ended up buying a new set. Get some anti seize on them when you put them back in...whatever you do!!!
You won't need to change U-Joints to change the H-pipe, but if you're just generally asking, you'll need a 12mm, 12-point wrench (and usually a hammer) to get the driveshaft bolts out.
Illuminator
10
29
So. Cal
Just did mine a few weeks ago...after no luck with the hammer method, I decided to take a 3ft crowbar under the car(with closed end wrench)with me. and after a few slips/skinned knuckles....managed to get the right angle down and worked like a charm....
mikestang63
SN Certified Technician
Aug 27, 2012
11,337
8,846
214
In the garage
If you are lucky, you can soak the O2 sensors with PB blaster for a few days and then they will come out. I had to heat them up a little and slap the air wrench and socket on them when then were hot and they finally came out. Definitely PITA without a lift.
just out of curiosity. what are the benefits to using an H-pipe or an X-pipe. is there a difference or is it just a what fits best? what kind of gains would a person hope to see by using this? is there a point of modification where this is necessary? or is this purely for exhaust scavenging benefits?
Gearbanger 101
9,457
1,378
234
Ontario, Canada
ReefBlueHatch
682
96
39
Central KY
I put the box end of my 12mm wrench on the driveshaft bolt at the 4-5 o'clock position and use my floor jack to push up on the wrench - loosens bolts free in a second without breaking a sweat!
ReefBlueHatch
682
96
39
Central KY
Yup, I forgot to mention that. I sprayed mine every time I walked through the garage for few days. I also let the car idle for 3-4 minutes right before I took them out so the pipes had some heat in them when I loosened the sensors - wear gloves for this!
