H&R Lowering Spring installation
  • Thread starter Thread starter JenkinsBS
  • Start date Start date Sep 2, 2011
First Prev 2 of 2
MFE92
1,094
373
124
Phoenix
Sep 5, 2011
#21
  • Sep 5, 2011
  • #21
Front
MFE92 said:
Position the spring so the bottom end (the one that isn't flattened) ends up between the two holes in the spring pocket. Position it in its pocket at the top, which may require raising the jack a bit just to hold it in place, and then get the jack positioned so the A-arm is roughly lined up.
rear
MFE92 said:
Swap isolators to the new spring, orient it so the flat side is up and the bottom pigtail points to the drivers side (for BOTH springs).
JenkinsBS
1,001
Washington
Sep 5, 2011
#22
  • Sep 5, 2011
  • #22
oy sorry, skipped right over that
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Sep 6, 2011
#23
  • Sep 6, 2011
  • #23
Had to use the spring compression tool this weekend. We changed lower control arms to TeamZ. I think I know why though. We used the stock springs, not lowering springs. When we lined up the lower control arm with the stock spring as we put the jack under it the car lifted off the jacks. Put the compression tool on, shrunk that spring down and everything lined up. I think if we had lowering springs it wouldn't have been an issue.
Just wait until you do upper control arms. The stock 20 year old bushing in the rear axle housing, not fun. Ditched the trash quad shocks too. These weren't doing anything, totally thrashed.
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Sep 6, 2011
#24
  • Sep 6, 2011
  • #24
GASP!!!
Oh, and I use Vibrant's method on the front springs. If by "zip off the bolts", he's talking about the nuts on the cc-plates. But you also have to unbolt the swaybar endlinks and the brake calipers.
VibrantRedGT
424
154
Boca Raton, Florida
Sep 7, 2011
#25
  • Sep 7, 2011
  • #25
Sharad said:
GASP!!!
Right, if there is no way of lowering the A-Arm any lower you will need to zip off a few other things. Although I'm thinking with a spring compression tool if you have one you can avoid some of that. I tried it this weekend and it's possible.
First Prev 2 of 2
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
R
Help to identify lowering springs
  • Rembrant
  • Feb 4, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 5, 2024
Mcmahst
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
