Had a problem
  • Thread starter Thread starter 87GT 306
  • Start date Start date Jun 24, 2005
87GT 306
260
Springfield MA
Jun 24, 2005
  • Jun 24, 2005
Started the new motor tonight and it ran but there was ticking and I shut it off after a few minutes. The corner of one of my rockers was hitting the corner one of the support ribs on the valve covers. Nothing extremely bad but there were some shavings. the covers are getting ground out tommorow but as far as getting the shavings out, we grabbed most of the junk with a rag then flushed it with some brake cleaner and oil. Won't the oil filter catch the debris if it makes it there?
J
JerryDaugherty
309
Near Dallas
Jun 24, 2005
  • Jun 24, 2005
Sure will. Also I learned this trick on my first car.. I dont know if it helps but it seems like it would. Get like 3-4 pretty good sized magnets... and put them on the oil filter I usually have like 4 good sized one to cirlce the filter. And you can just leave them on they wont fall off .Anything that goes in there will stay in there hope this helps.
87GT 306
260
Springfield MA
Jun 24, 2005
  • Jun 24, 2005
thanks... So if I do that I wont have to worry about any shavings making it past the filter?
The filter is going to be changed after the intial break in too.
J
JerryDaugherty
309
Near Dallas
Jun 24, 2005
  • Jun 24, 2005
Id be surprised if anything got past that. I would change it right after the break in becuase it will be pretty clogged with all the little shavings and assemble lube. even after you get a new filter go get a pretty good size mag about the size a radiator cap and keep it on there it wont fall off and if anythign deicides to wear prematurely it will get it.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
