Ok i already did the IAC trick that I found in a search on stangnet and it worked untill the computer learned what I was doing. Now the computer is setting a high idle speed code and it seems that the IAC trick only works for a little bit. If I clear the code it seems to work fine, but after a little time goes by, it starts to idle high again and then the light comes back on. Also do I need a tune with the mods I have. I have never really had a tune but now my anderson pms took a dive, so I hope thats not my problem. Thanks for any help.
