Before I start, I did do a search.
I've checked all the vacuum hoses, no apparent leaks. I've done the battery disconnect/headlight knob on computer reset to clear the memory.
3 weeks ago I installed a Trick Flow Track Heat upper and lower intake manifold, a Dragon 75mm throttle body, and a JLT cold air intake.
Now I have hanging revs. Revs will hang at the position the gas is let off at, then slowly drop down to 1800, hang there for a moment, drop down to 1500, hang there for a moment, drop down to 1200, and then gradually lower themselves down to a proper idle.
Anyone out there who has diagnosed or worked on this sort of problem in the past, please help to point me in the right direction here.
