My 90 gt has a real harsh ride. The suspension is all stock. Since i live in jersey and the roads are all horrible and i was wondering if there is anything at all i can do to soften up the ride with out loosening up the feel of the car?
Do you have Z-rated (or higher) tires on it? If you do, you could go down to H-rated tires, or even touring tires if you aren't going to run it fast. The thinner sidewalls will soften the ride.
i already ordered all the bushings shocks and struts, wondering if i should do the front springs as well. I have z rated tires but i dont really intend on changing them just bought em and it didnt seem to change the ride much from the h rated ones that were on it when i got the car
Sub frame connectors will also help smooth out the ride. Instead of the bumps being transfered throughout the sloppy unibody...the suspension is forced to work more independently and you get a smoother ride.
Springs arent going to do all that much for you in terms of softening it up. The lowest springs rate the better obviously (in terms of soft rides) but also make sure they are progressive rate.
The more you drop the car with springs...the more the suspension geometry is going to be off...so i would should for a 1" - 1.5" drop at most. Look at the ford spring kits. Good luck man
