Hard starting
  • Thread starter Thread starter tc67pony
  • Start date Start date Apr 25, 2004
T
tc67pony
60
St. louis, mo
Apr 25, 2004
  • Apr 25, 2004
My car usually starts up first turn when its cold, along with one or two pumps of the gas to turn the choke on. But when I drive for a while and it gets up to running temp. and I go to restart it it will take a while to start. It sounds like my timming is to far advanced, but its only at about 8-degress, the only way she'll start up again right away is to give it more gas while starting it when its hot, but usually I don't need to do this. Its like whats the deal. It acts as if its flooded, but its not. I don't know any suggestions.
NorCal66
334
Virginia Tech, Blacksburg, VA HOME
Apr 25, 2004
  • Apr 25, 2004
Mine isn't too bad to start when, hot, but definately not half as fast as a cold start. If it's really tough you might want to try a starter heat shield?
MustangMatt1966
1,004
Orlando Fl.
Apr 25, 2004
  • Apr 25, 2004
mine does the same thing tc67pony, starts so easy cold, but once hot, it turns over for a bit before starting??? i dont know what the problem is
E
eats305sstock
1,111
  • Apr 25, 2004
I've found that my car will be harder to start after sitting for 15minutes to about an hour. To fix it I usually feather the throttle a bit while the key is in the start position and this keeps the engine from dying right after startup.
sand1man
299
Charlotte, N C
Apr 25, 2004
  • Apr 25, 2004
Mine is just the opposite, Is it turning over fine when it is warm or is it dragging some
T
tc67pony
60
St. louis, mo
Apr 25, 2004
  • Apr 25, 2004
yes, feathering the throttle definetly helps, but I have had a couple of people tell me to look into a heat sheild.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Apr 25, 2004
  • Apr 25, 2004
starter is dragging as its most likely overheating because the exhaust pipes are real close to it. As stated, you can purchase a heat shield for the starter. . Another possible fix is a high torque mini starter, which gives you more space from the exhaust.
MustangMatt1966
1,004
Orlando Fl.
Apr 25, 2004
  • Apr 25, 2004
ahhh it all makes sense now
ratio411
3,870
73
109
Pensacola FL
Apr 25, 2004
  • Apr 25, 2004
Sounds like a heat soak condition at the starter as some have put forth.
Timing would be another problem, but you have ruled that out.
Next could be a heat soak condition in the fuel system, aka vapor lock.
These would be the areas I would look at long and hard.
Good luck
Dave
65fastback2+2
1,229
Louisville, KY
Apr 25, 2004
#10
  • Apr 25, 2004
  • #10
my 65 FB did this, i agree with the starter, it sounded ALOT weaker during a warm startup. It would nearly sound like my battery was dead o.O
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 26, 2004
#11
  • Apr 26, 2004
  • #11
Since you didn't mention that it was slow turning over, I wont presume it is a dragging stater. More like a too rich choked condition, or poor tune. Check the condition of the plugs, points if you have them, carb idle mixture screws and it may be posible that you have a float problem.
T
tc67pony
60
St. louis, mo
Apr 26, 2004
#12
  • Apr 26, 2004
  • #12
No its a daily driver just about, I have electronic ingnition so points are out. Somtimes the starter will turn over very slowly--like the battery is dead or somthing, but once I give it gas the starter will spin faster and the engine will usually start. It could be running a little rich on the choke, but I also need to check my air fuel mixture too posibbly, I need to get my vaccum gauge out. But now I really do think its the heat from my headers.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 26, 2004
#13
  • Apr 26, 2004
  • #13
Yea, could be.
H
hdgapeach
24
#14
  • Apr 26, 2004
  • #14
Check the condition of your cables also. If the starter is spinning slow, the cables are heating up. Clean all connection points to guarantee good contact and r&r anything that is corroded or weak. I went to a larger guage cable set up on mine and eliminated the same problem that you are having with warm starts. Worth a check and might find out that you aren't in need of a starter.
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
