  • SN95 4.6L Mustang Tech
hard to get into reverse
  • Thread starter Thread starter supastang03
  • Start date Start date Apr 14, 2004
supastang03
214
Miami/Gainesville UF
Apr 14, 2004
  • Apr 14, 2004
i was wondering if this is all stangs or just mine. when i try to put it in reverse(5 speed tranny), it seems really hard, and i have to force it into reverse pretty hard. sometime this even happens in first gear...does this happen to anyone else? it must be bad to force it into gear, right?
john_324
446
Washington, D.C.
Apr 14, 2004
  • Apr 14, 2004
I sometimes get a recalcitrant reverse as well. Usually letting out the clutch, putting it back in and then trying again does the trick though...
Brisk281GT
340
Naperville, IL
Apr 14, 2004
  • Apr 14, 2004
I have had this from time to time. This seems to happen on most 5-speeds and not just stangs. I have noticed this on past cars (my Integra, my talon) and current cars (my Stang and my truck).
My fix that seems to work each time is not to force it into the gear that won't go, I doubt it's good for the tranny. If it won't go into 1st I put it into one of the middle gears (like second for example if you are trying to go to 1st) for just a moment. This seems to unlock 1st then. For reverse I just slip it fully into another gear that is close by like 5th. Do this for just a moment also and then slide it into Reverse.
I think it just depends on where you stop the tranny. It seems like it gets stuck between gears or something and it just takes some other gear movement to get it unstuck.
supastang03
214
Apr 14, 2004
  • Apr 14, 2004
yea that what i was thinking...i just didnt know if this was something that normally happened on 5 spds. thanks for the help guys.
Blakers01GT
Master of the Clubhead
2,110
Brown Deer, WI
Apr 14, 2004
  • Apr 14, 2004
yup I get it too, I do everything Brisk281GT said
I always find if I gently put it in reverse, like let it pop in by itself rather then jam it, it goes in more often then not.
bergs
117
new jersey
Apr 14, 2004
  • Apr 14, 2004
i always put it in 4th before i go into reverse, and i always put it in 2nd before i go into first, i do this in any car with a stick.
dahun
102
California
Apr 14, 2004
  • Apr 14, 2004
I thought that even reverse was synchronised on the tremec tranny's, I never had a problem getting into reverse...
...OTH, talk to me about shifting between 1st and 2nd...
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Apr 14, 2004
  • Apr 14, 2004
I was told that its hard to put in reverse, becasue reverse has no sycro. put it in firast then reverse. thats what I do
JonJon
4,801
back in Marylands
Apr 14, 2004
  • Apr 14, 2004
Reverse is a PITA for me. Putting it in 5th first then shifting into reverse works most of the time. If it doesn't, I roll forward a little then it goes in.
V
VatStang
88
Santa Clarita, CA
Apr 14, 2004
#10
  • Apr 14, 2004
  • #10
What I do is to very slightly let out the clutch with a tad bit of gas while I am putting the 1st or reverse gear in the gate. It goes in like butta.
Brisk281GT
340
Naperville, IL
Apr 14, 2004
#11
  • Apr 14, 2004
  • #11
Nothing is worse than sitting at a light and then the stupid car won't go into 1st when the light changes. It just kinda gets you by surprise.
jeff1414
447
Sacramento
Apr 14, 2004
#12
  • Apr 14, 2004
  • #12
Me to I have to go from fifth to reverse. To get it in if that does not work then I let out the clutch then try again and it works most of the time!
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
