hard to start when cold/low power
hey guys i got a 92 5.0 lx 5speed. first thing in the morning its hard to keep runnin till it gets some heat in it and even the it run ruff till you drive it for about 10mins after that it smooths out and idels better but still feel like its low on power. having said that i have had this car a wile and has just started having little thing go wrong in the past month, i have put new plugs,wires, hole new distb, fuel pump injectors out of 99 explore along with the upper and lower intake, it has bbk long tubes, and a gear but other than that its all stock for now bottom end has over 300k by what i get from carfax... any ideas guys?
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
