Harmonic balancer for 351 W
  • Thread starter Thread starter SwedeMach1
  • Start date Start date Jun 3, 2007
SwedeMach1
Trollhättan, Sweden
Jun 3, 2007
  • Jun 3, 2007
I'm interested to know if there´s someone out there that has tried to get an aftermarket Harmonic balancer for high performance, to fit an engine with AC and PS.
I've got a -69 mach 1 with a 3 sheeve crank pulley. The stock balancer is only about 0.750" thick and my Romac balancer is about 2" thick. Obviuosly I can't fit the pulley to that damper since I would have to move PS pump, AC and waterpump pulleys by 1.25"
Does anybody know if there's an aftermarket high performance balancer that is no more than 0.750" thick or do I have to look for an original replacement?
As always, any input is appreciated
D
D.Hearne
11,730
south louisiana
Jun 3, 2007
  • Jun 3, 2007
The stock balancer ring may be .750 thick, but the hub the pulleys sit on sticks out farther. I've run across 2 different offsets for these on small blocks, Measure the length from inside the hub using a tape measure from the edge that goes up against the timing gear forward to the flange the pulley rest's on. Then make a decision as to what aftermarket balancer you need. The 70-up balancers all have about a 4-1/4 or 1/2" distance here.
SwedeMach1
Trollhättan, Sweden
Jun 3, 2007
  • Jun 3, 2007
harmonic balancer
I've found some company called Damper Doctor and I've got a couple of pictures of dampers from that website. My damper looks like this: http://www.damperdoctor.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=DD&Product_Code=FOR3021&Category_Code=FOR
As you can see, the flange that goes against the pulley isn't that much taller than the balancer ring. I've come across another damper that probably would correlate to my Romac. It looks like this:
http://www.damperdoctor.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=DD&Product_Code=FOR3517&Category_Code=FOR
The biggest problem is that the companies that sell the dampers rarely specify anything else than the imbalance weight and the dia. Anyway, I'll measure the damper as you told me and then I'll be hunting for a replecement for the Romac.
Thanks!
D
D.Hearne
11,730
south louisiana
Jun 3, 2007
  • Jun 3, 2007
Ok, I see you've got the 3 bolt balancer, the 4 bolt style has the balancer ring closer to the timing cover. You'd need something similar to the Boss 302 or 289 Hi-po unit.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Crank Trigger Install on 94/95 302/351 setup
  • moneypit94
  • Sep 3, 2018
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Sep 5, 2018
jozsefsz
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
1990 On3 Turbo Build/Review
  • BryanNux
  • Feb 18, 2019
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2019
a91what
