  • 1994 - 1995 Specific Tech
Harmonic Balancer MISSING?!
  • Thread starter Thread starter sKyZ
  • Start date Start date Sep 21, 2005
sKyZ
138
Scranton PA
Sep 21, 2005
  • Sep 21, 2005
Alright, I just had the shop put in my holley 155lph fuel pump and find why my car was smelling like gas. It's the rubber piece from the filler neck.
anyway, they also noticed that my harmonic balancer isn't there.. Is there any reason the person before me would take it off? Maybe to rebalance the crankshaft because a bearing was ****ed? I mean.. I got the car for 3500 and already I had to replace the tranny.. If this is off that means the engine is pretty ****ed and he just did it so i wouldn't hear the noise of the bearing.. any other ideas?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 21, 2005
  • Sep 21, 2005
sorry dude, I don't even know what to tell you. because I don't see how the crank pulley was even bolted up without the balancer....
Scott
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 21, 2005
  • Sep 21, 2005
yeah and you would have a massive oil leak too
sKyZ
138
Scranton PA
Sep 21, 2005
  • Sep 21, 2005
it's like the rubber piece near the pully.. behind it.
RIO5.0
6,892
N.H.
Sep 21, 2005
  • Sep 21, 2005
No balancer???....Something's wack....
sKyZ
138
Scranton PA
Sep 21, 2005
  • Sep 21, 2005
yeah, but what's "wack"? I mean... yeah.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Sep 21, 2005
  • Sep 21, 2005
Mabe that's what the tech dude told you ... but what he meant was probably that the rubber behind it is ate up. That's how you KNOW it is bad. Replace the rubber & balancer ASAP!!!
sKyZ
138
Scranton PA
Sep 21, 2005
  • Sep 21, 2005
so there's no reason why the balancer would be off...performance..to "cover up" a error or ****up on the crank..etc?
sKyZ
138
Scranton PA
Sep 21, 2005
  • Sep 21, 2005
yeah, the rubber is ate up.. he showed me.
yellowstang1994
338
#10
  • Sep 21, 2005
  • #10
yea, don't drive that crap anywhere until you get one in. They are very easy to do, it took me an hour the first time I ever done one.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Sep 21, 2005
#11
  • Sep 21, 2005
  • #11
While we're at it ..... is there a nice little write-up on this?
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Sep 21, 2005
#12
  • Sep 21, 2005
  • #12
Oh, & when he said the blancer is "off" .... I think he may have meant "out of wack" (instead of missing, lol). This can cause serious damege to your engine!!!! Fix it ASAP .... don't drive it until you do!
1994Vib.RedGT
585
Denver, CO
Sep 21, 2005
#13
  • Sep 21, 2005
  • #13
speaking of replacing them, I am about to do mine, can anyone tell me how exactly to do it.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Sep 21, 2005
#14
  • Sep 21, 2005
  • #14
Remove the crank pulley, and crank bolt. Use a balancer puller to get the balancer off, I used an impact to take the crank bolt out then a bit 1/2" drive wratchet for the puller. If you don't have an impact put the car in 5th gear if its a manual then you should be able to brack the crank bolt loose. Once the balancer is off, put the new one on lining up the groove. I used a deadblow hammer to tap it on most of the way then used the crank bolt to finish it off. I'm sure there is an installer for it.
steps...
1. remove pulley
2. remove crank bolt
3. remove balancer
4. put new balancer on and tighten up crank bolt
5. put pulley back on
yellowstang1994
338
#15
  • Sep 21, 2005
  • #15
Sorry don't mean to confuse by adding anything else. But when you begin you should take off your fan shroud and the coolant overflow tank out of the way. Not hard to do at all but gives you a lot more room. I don't think I had any room to put the puller in there without them off. When I put my new balancer on I didn't have to force it or anything, it just slid on like butter. I guess everyones is different though, just make sure you clean the surface very good. They should have supplied instructions with your balancer. It is a job you can do at home so don't go out and spend a lot of money for someone else to do it. When your done you'll say to yourself how easy it was.
GRGT1994
1,034
#16
  • Sep 21, 2005
  • #16
Put ATV on the key groove in the balancer, and a good bit of it on the back of the washer for the crank bolt.
The crank bolt torque spec is 110 to 130.
Pick up a Haynes or Chilton manual for all the details.
But this is easy to fix, and you DON'T want to drive on a balancer that goes out. (I cracked my timing cover)
Venom351R
4,548
41
98
MAINE
Sep 22, 2005
#17
  • Sep 22, 2005
  • #17
well its not missing is still there. It just needs to be replaced. Pretty common once your miles get up there.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
