  • 1994 - 1995 Specific Tech
Harmonic Balancer
  • Thread starter Thread starter Emoney8924
  • Start date Start date Sep 14, 2006
1 of 2 Next Last
Emoney8924
77
columbia, ct
Sep 14, 2006
  • Sep 14, 2006
Im trying to remove the balancer and it is completely rusted/stuck on. Ive tried to remove it with the puller and it ended up breaking the puller itself so I returned it and got a new one. Im gonna try again in a little while..
Are there any helpful hints or anything to get this thing off?
Thanks
Eric
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Sep 14, 2006
  • Sep 14, 2006
LOTS of penetrating oil.
If you can find soem Kroil get that, it works wonders, but its like $30 for a 12 oz spray can.
But well worth it IMO.
R
RyClef331
118
Jacksonville,NC
Sep 14, 2006
  • Sep 14, 2006
Not trying to be a dick or question your intelligence....but did you take the bolt out of the center? don't laugh...I've done it.
Bosko5.0
1,067
longwood, FL
Sep 14, 2006
  • Sep 14, 2006
try tapping it with a persuader if that doesn,t work get a bigger persuader.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 14, 2006
  • Sep 14, 2006
also DONT FORGET THE WASHER. a few people on here have removed the bolt but forgot to remove it and done the same thing you have (break the tool)
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Sep 14, 2006
  • Sep 14, 2006
MEEE!!!!!!!
Emoney8924
77
columbia, ct
Sep 14, 2006
  • Sep 14, 2006
i used a really big persuader haha
yes i did take the bolt out ..
nothing worked yet,
thanks though
Emoney8924
77
columbia, ct
Sep 14, 2006
  • Sep 14, 2006
ok, so i think ive quit for the night... its still not out.. I've been beating on this thing mercilously. the big weight that actually sits on the hub itself slid right off, so now im just beating on the hub.. This thing will not give in, and now it is basically to the point where nothing will hold the crank from staying still, i will go to rotate the puller, and the thing will move, ive used vice grips and leaned them up against the water pump housing, to the point where the vice grips feel a little weak.. Im about ready to say screw it and just spend like a half hour beating it with a hammer... oh yea also, i have used possibly a whole can of pb blaster on it, all around it.. any ideas guys??? thanks a bunch!!!
Eric
HISSIN50
34
129
Sep 14, 2006
  • Sep 14, 2006
Right-on about the washer tip.
EDIT due to most-recent post above:
Dont use a hammer please.
The car is in gear with the e-brake applied?
The hub and crank are keyed - so the balancer hub doesnt spin without the crank turning, right?
Good luck.
Emoney8924
77
columbia, ct
Sep 15, 2006
#10
  • Sep 15, 2006
  • #10
yep to all, washer is out.. and everything.. dont know what to do from here. haynes makes it sound so simple... "remove bolt, use harmonic puller to pull vibration damper off"
Bosko5.0
1,067
longwood, FL
Sep 15, 2006
#11
  • Sep 15, 2006
  • #11
try using an impact wrench, too stop crank from turning remove the inspection plate on your tranny put a wrench on one of the flexplate bolts to hold it then try using the pulley.
Good Luck
HISSIN50
34
129
Sep 15, 2006
#12
  • Sep 15, 2006
  • #12
Sorry - I missed the auto trans part. See Bosko's post.
There's another horrid method but we won't go there.
Good luck.
MLC Stang
210
Atlanta, GA
Sep 15, 2006
#13
  • Sep 15, 2006
  • #13
Eric,
The only thing I haven't seen suggested here is HEAT!
Many times with stuck bolts, stuck anything that's metal, I have gotten them off after heating the stuck part up with a propane torch.
Warning! Be careful not to set any kind of solvent or other fluid you might now have on the part on fire! Make sure it's clean and dry before heating with a torch.
Good luck with it.
PS) Day-um! I see I've been promoted to a "Founding Member", even though I'm not. Guess I better run out quick and get a Lotto ticket!
WHITE94COBRA
816
HUNTINGTON BEACH
Sep 15, 2006
#14
  • Sep 15, 2006
  • #14
The heat will work, however are you going to reuse this balancer? Is it a stock piece? If it's stock chances are your going to burn the rubber in the middle of the hub, if it's aftermarket like a fluidyne, it will heat the fluid in the hub, which will change the characteristics of how it works, so in short your going to need a new one if you heat it up.
Emoney8924
77
columbia, ct
Sep 15, 2006
#15
  • Sep 15, 2006
  • #15
no i have a new one sitting there, swapping because there is a horrible shaking in the car.. I have heard of heating it with a torch, crappy part is i dont have a torch.. Im gonna try messing with it today, and if not then, i think ill go out and buy a torch
HISSIN50
34
129
Sep 15, 2006
#16
  • Sep 15, 2006
  • #16
Heating a hub with the balancer on the car might not play nice with the crank seal.
MLC, congrats. I think you get it after being here retroactively 4 years from the present.
Emoney8924
77
columbia, ct
Sep 15, 2006
#17
  • Sep 15, 2006
  • #17
good thinking.. didnt think of that!! ok so when does the woodruff key come out.. when eveything else comes off??
HISSIN50
34
129
Sep 15, 2006
#18
  • Sep 15, 2006
  • #18
The key is in the crank and the balancer has a keyway.
During a normal R/R, the key should not come out of the crank (though they can come out).
With luck you wont have issues with yours........
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 15, 2006
#19
  • Sep 15, 2006
  • #19
Is there a way to cool the crank and heat the balancer somehow. b/c idk of any other way to get it off if the puller is indeed usless.
Maybe get one of those cans of compressed air, which blows pretty cold. Once the balancer is hot, take the torch away, and spray the compressed air inside the crank. Maybe that will loosen it up??
Just a random thought. But you should note that the compressed air is likely flammable (propane propellant maybe?) and it shouldn't be sprayed near the torch.
Scott
Blackened302
1,439
South TX
Sep 16, 2006
#20
  • Sep 16, 2006
  • #20
good bit of info. my hb busted on the way home from the track tonight so i'll be doing this tomorrow.
1 of 2 Next Last
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
