harmonic balencer
  • Thread starter Thread starter trips52
  • Start date Start date May 26, 2004
trips52
172
ocala, fl
May 26, 2004
  • May 26, 2004
ok i put o a new harmonic balencer from 5.0 resto...... when puttiong it on the bolts from the old balencer won't work they needed to be longer because the new balencer is not threaded but relies on the bracket in back of it to hold the bolts...... aftera month of running it snaped the bolts from the crank pulley..... WTF.... now im stuck agian..... anyone else have this prob....... o yeah it is a underdrive pulley too do i need special bolts... i know the ones we put in were kinda short ,,, but the did thread in most the way.... should i go with a bolt that is not threaded all the way down......
TheBocSez
652
Converse, TX
May 26, 2004
  • May 26, 2004
When I put on my underdrive pulley, I couldnt use the stock bolts because the bolt head was too big. I had to use bolts with a rounded head that are tightend with an allen wrench. As far as bolt length, I dont remeber 100% but the new bolt were the same length or maybe a little shorter, but they have worked fine, the old bolts would tighten some but then the bolt head would rub on the pulley. Either way, I have a brand new set of bolts for the underdrive pulley with the rounded head if you want them, just send me your address and Ill mail them to you. PBocconcelli@satx.rr.com
Iowa91LX
2,616
Grundy Center, Iowa
May 26, 2004
  • May 26, 2004
The smaller pulley requires you to use either an allen head or torx head bolt. I prefer to use allen on my stuff, but thats just a personal preferance. Ive stripped out to many torx bolts in my life.
Icepick
378
Ft Lauderdale
May 26, 2004
  • May 26, 2004
The balancer i just got yesterday from 50resto.com is a remanufactured Ford part, I also got the MAC underdrive pulleys which came with the rounded allen head bolts because as mentioned above you can't fit a socket around the original bolt heads. Otherwise everything bolts in just fine.
trips52
172
ocala, fl
May 26, 2004
  • May 26, 2004
my balencer from 50 resto is not threaded like the stock one. it is straght though and the bolts thread into the plate in the back....is this ok it didn't come with new bolts ........
HISSIN50
34
129
May 26, 2004
  • May 26, 2004
i would not feel comfy with that - have you called the manufacturer (Performance Products, etc) to find out for sure. or their site might have install tech....what kind of balancer is it? im just curious so i never buy one (i almost got the PP non SFI street unit for 80 bucks)....good luck with that and the bolt issue (your other thread).
trips52
172
ocala, fl
May 26, 2004
  • May 26, 2004
yeah i don't feel comfy with that eather it is a performance product, ect... i am going to call them tomorrow to see if this is normal.....
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
