Harsh Vibrations!
  • Thread starter Thread starter phazersonstun
  • Start date Start date Nov 17, 2007
P
phazersonstun
29
  • Nov 17, 2007
So I dropped in an 1988 roller-cam 5.0 into a 67 coupe. The car is pretty much together but I get a NASTY vibration when I rev it. I Know that the original 289 was internally balanced while the late-model engine is externally balanced. I had to use the old flywheel from the 289 because the 51oz for the 5.0 was too large for the C4 transmission's bellhousing. Is this my problem or is it something else? Any help would be greatly appreciated.
bnickel
5,640
lubbock, texas
Nov 17, 2007
  • Nov 17, 2007
that is most definitely your problem. the balance factor for the 2 engines is so much different that it is causing the engine to basically fight itself on every turn of the crank. you need a flexplate for an 81 or 82 302 with the small bell c4.
C
C0V3R
524
Australia
Nov 17, 2007
  • Nov 17, 2007
btw its 50oz not 51oz
bnickel
5,640
lubbock, texas
Nov 17, 2007
  • Nov 17, 2007
true, i didn't really feel like pointing that out though.
P
phazersonstun
29
  • Nov 18, 2007
Really? Great! So where can I find one? I haven't seen an such an early V8 at the junkyard in a long time. Could I find a flywheel from a similar platform?
50oz. Got it.
rbohm
6,698
550
204
tucson,az
Nov 18, 2007
  • Nov 18, 2007
here are 4 such flexplates from summit racing;
http://store.summitracing.com/egnse...94905612+4294863728+4294840126+115+4294871826
BornInAFord
199
Bend, OR 97701
Nov 18, 2007
  • Nov 18, 2007
You can also have a machine shop rebalance your current flexplate to 50oz, too, although this may be as expensive as just getting a new correct one or finding one on ebay. You definitely DO NOT want to run the car as you currently have it as it will tear itself apart in quick order.
BTW, all factory 260, 289, 302, 5.0L and 351W engines were externally balanced. The difference is in the balance weight on the flywheel/flexplate and front harmonic balancer.
CraigMBA
783
Orange, CA
Nov 18, 2007
  • Nov 18, 2007
And while you're at it, what damper did you use?
P
phazersonstun
29
  • Nov 19, 2007
I am using the stock 5.0 dampner. Why do you ask?
Pbum5
515
Minneapolis, MN
Nov 19, 2007
#10
  • Nov 19, 2007
  • #10
Because - You need the correct balance dampener and flywheel/flex plate for your application.
CraigMBA
783
Orange, CA
Nov 19, 2007
#11
  • Nov 19, 2007
  • #11
Because that one's 50 oz and OK and the other one is 28 oz and isn't OK.
bnickel
5,640
lubbock, texas
Nov 19, 2007
#12
  • Nov 19, 2007
  • #12
the 5.0 balancer is also balanced for the 50oz imbalance of the 5.0 motor as well as the flexplate. same goes for the early 28oz motors, the balancers and flexplates must match there as well.
P
phazersonstun
29
#13
  • Nov 19, 2007
  • #13
Right.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 12:05 PM
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
