Has anyone made a checklist for PI headswap?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Here is what I have so far and feel free to add to it, I would like a list of EVERYTHING that is needed to do it in 'one stop.'
01+ heads (reuse valve covers)
01+ PI intake
01+ Cams
01+ Headgaskets
01+ Valve Cover gaskets (aka: Cam cover gaskets)
01+ Intake gasket
Header Gasket
Headbolts
Alternator bracket
Coolant tube and nipple (Does it matter what year?)
Timing Cover gaskets (aka: front cover gaskets)
Crank seal
Crank and cam sprocket bolts
Plenum O-rings
Thermostat O-rings
Water Pump O-rings
Header down-pipe gasket
Stock or 180* Thermostat
18mm Balancer bolt and 18mm Cam Retainer bolt.
F8AZ-10153-EA - Alt. Bracket for Pre-99 with aluminum crossover PI intake.
What else is needed? Does the above list look correct? Feel free to add up!
As far as 'special tools' I see that you need a 10mm 12pt open-end wrench for the powersteering bolt, a 13mm deep well socket for a valve cover bolt.
Does the waterpump need a nipple?
What size cam bolts do you need for the 01+ cams that go on the 96-98 engine?
