has my differential gone?
jef0509
83
New Jersey
When I come to a stopsign making a right turn, I accelerate out of the turn in first - but when I hit the gas my car revs high but I don't feel the power getting to the wheels, sometimes it will kick in when the tach gets to 4-5k but sometimes I have to shift before I start seriously accelerating. This also happens sometimes on a straight away in first gear when I am at wot, but rarely, mostly on turns. Is this my differential? I thought when the differential went it would make my inside tire smoke when I go around a sharp turn. Also, what would fix this? I am going to get gears soon, so I want to fix it while I'm in there. I thought at first it might be the clutch, but the clutch only has 10k miles on it and there are no other signs that its worn.
btw its a 91gt w/ 100k miles
Thanks in advance, hope it wasn;t too confusing
Jeff
It's the clutches inside your rear end, I got new ones for $40 somewhere online. Once you put those in, your car will feel totally different, and you will be sliding on turns :p
When they go in, make sure you soak them in friction modifier for at least 15mins, and put it all in.
