HATCH WONT CLOSE!!!!!!!!!!!!!!!!!!!!!!!!!
DirtyD916
804
Norcal 916
The hatchback on my 88 gt wont close right. YOu have to slam it down and then even with it in the "closed" position, there is like half an inch or two of play up and down. Its like the hatch lock thingy is bad or something. I figured a new one would fix the prbolem. Anyone else agree? :shrug:
yeah it's probably the striker. Oddly enough I just tightened up mine today. To tighten it up you can either use a torx bit (T20 I *think* but I could easily be wrong). Or you can use a pair of vice-grips and just turn it. Also you might need to replace the plastic part on it. You can get new plastic for it at almost any parts store. The striker moves up,down,left and right. Your hatch probably wont bounce around after you fix it up.
man finally. thanx. Y ai was thinking that i could just titen it up. I just thought that the stocker had just seen its last latch and was now a little too worn out to work. Oh well i will see in a sec.
or you can go to texasmustang and get their hatch renewl kit thats what i did with mine and it has no play in it at all.i think they cost like 67 bucks. you get weather stripping,supports,and of course the striker.
