I am converting my car to EFI, i called ford racing and they said that I cant use my old gas lines that i need to get a tank out of a 86-93 stang, will this be a direct bolt in since mine is a 84? He also said if I go with the FMS wiring harness then I need the o2 sensor harness, and the fuel injector harness, out of a 91-93 mustang because the connector pins are a different size
i have no idea what this means, so are the harnesses different from year to year? Does anyone have a wiring diagram i can print off so I can have somthing to look at when i am wiring all of this wonderful stuff up
Thanks in advance
also will a mass air cpu out of an automatic stang work with my 5 speed?
Thanks in advancealso will a mass air cpu out of an automatic stang work with my 5 speed?
