Have a problem and need help
I just got my car running a couple days ago, and now I have a problem. THe mods I did are
A/C delete
Smog Delete
MAC equal length headers
MAC prochamber
BBK 255lph fuel pump
Its a 1988 GT, thproblem is, my car will run perfectly normal while the engine is cooled down or from a cold start, then when I hit running temperature, my car starts to have no power at all, I mean it drives and stuff, but I go to step on it and it sputters and misses. I still have stock injectors also that leak.
what could be the problem(s)
Thanks
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
