Having a really hard time shifting
PeteyAce
346
its snowing here in nyc not much a few inches. but i couldnt put my car in the garage as of yet. i been using the stang to go back and forth since its my only car. yetserday i had no problem with it, but today as soon as i was driving my car today it was impossible to shift, first and second are impossible to get into. third and fourth arent to bad, and it got stuck in gear where i had to used to hands to get it out. im thinking the cable or something i have a stock cable and the clutch was changed less then 6months ago
sounds like the clutch isn't engaging fully. do you have a stock clutch quadrent on the car? if so sometimes the plastic teeth wear and you have to reach up there and kinda get it tightened to the next tooth mine always did that and i went and bought some aftermarket jobbie
Where is the point of engagement? How much freeplay do you have? It sounds like a low POE (near the floor) and lots of preload.
Good luck.
quadrent should be stock, it engages when its only all the way down but sometimes it shifts easily but most of the time i have to put a lot of muscle into it especially when im downshifting
yah your clutch quadrent needs adjusting. its a clear kinda plastic thing (technical term) under dash. you can trace the clutch cable to it. you can pull a piece down and put pressuer on the quadrent (thing looks like a 1/4 circle with teeth) and take the slack out of your cabble.
Just try pulling up on the clutch pedal with your foot - that is how it should self-adjust (if the pawl is not stripped).
Good luck.
PeteyAce said:
i acutally lifted it with my foot before it had no effect
Then it sounds like either your cable is stretched out of spec or your quadrant and pawl's teeth stripped.
ok before i posted the thread i spoke to my uncle and he told to to lift up the clutch with my foot too it didnt work, 20 mins ago i thought id tried it again and it seemed to shifter better i only had trouble getting it into first only, but rarley just again guys, seriously though i dont know what it is about winter that brings out the worst in my car
One thing to remember is that the plastic on the quadrant and pawl is umpteen years old. The teeth might be on their last legs, so it is not adjusting (ratcheting) like it should.
A new quad and FWA can be had for around 40 bucks. Might be a gift idea. :)
if it grabs RIGHT off the floor, then your adjustment is too loose. Get a good aftermarket firewall adjuster and quadrant, that'll help tons with getting it into gear. Read up on my sig link if you want more info on the subject.
