  • SN95 4.6L Mustang Tech
Suspension Having Issues...cant Locate Cause?
  • Thread starter Thread starter rabidscoobie
  • Start date Start date Dec 16, 2014
1 of 2 Next Last
rabidscoobie
616
12
48
College Station,TX
Dec 16, 2014
  • Dec 16, 2014
I have an 04 Mach 1 that is feeling really loose while driving.
The issue is while under acceleration,just normal the front of the car pulls to the left and feels as the rear pulls to the right and the front seems to lift slightly.
At the same time this happens I have to slightly pull the steering wheel to the right,when I lift off the throttle it returns to normal position.This is even more pronounced under heavy acceleration.
I am suspecting possible worn rear shocks,but I really dont know and see nothing wrong under the car when on stands.
Any ideas?
Additional car info.
Has about 80,000 miles.
Has original shocks on it and suspension.
around 2010 Ford install a complete rear end,housing gears.Re-installed my original brakes,rotors, calipers etc...but with 4:10 gears.Also used the original suspension parts.
During the summer I had an odd squeaking sound coming from the rear just behind the driver seat on driver side.I tried several times to locate it but was never able to since it would only do it while driving and sporatic at that.Was more noticeable under acceleration and when letting off throttle.It has then stopped but thats when the current issue seemed to produced itself,and I think it may be slowly getting worse.
I have checked everything I could but found nothing that stood out.I put wrenches on all the bolts I could find to make sure nothing was lose since the local Ford Techs are just awful here,they can do some really stupid things that make no sense.
I actually got into an argument with one when they did the rear,he was trying to tell me that the wheel sensors controlled the speedo and that while he was going 70mph all 4 wheels were turning the same speed so nothing was wrong.....WTF!
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 16, 2014
  • Dec 16, 2014
No rattles going over bumps and such?
rabidscoobie
616
12
48
College Station,TX
Dec 16, 2014
  • Dec 16, 2014
Nope no noises at all.
Now when it was making noises as explained it would make the same squeaks going over speed bumps.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 17, 2014
  • Dec 17, 2014
That is probably spring squeak from worn isolators. Lift the car and see if there is any play in the front wheels. Try rocking them side to side and up and down
rabidscoobie
616
12
48
College Station,TX
Dec 17, 2014
  • Dec 17, 2014
So I understand correctly, if the front isolators are worn I get spring squeak in the rear of the car?
Also I forgot that the rear seems to squat more under throttle.
At say 60-70mph if I lay into it, suspension feels really loose. Recently a car pulled out in front of me and had to evasive maneuvers and the car felt like it had more body roll than normal.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 17, 2014
  • Dec 17, 2014
No...spring isolators in the rear will give you a squeak in the rear but that shouldn't cause the suspension issues you describe. I thought you were having issues in the front as well since you said the cars drifts under accel.
Wouldn't hurt to take it to an alignment shop and see what they tell you. They can check the front to rear angles and see if there is anything amiss. Some places will check it and not charge if there is nothing out of sorts but that is hit and miss.
rabidscoobie
616
12
48
College Station,TX
Dec 17, 2014
  • Dec 17, 2014
Ok just wanted to be sure what you were saying.
Ill get under and do some more looking.Suspension isnt really one of my strong points on cars.
Thx for the help and any other info is appreciated.
DIYdudeguy
27
Earth
Dec 17, 2014
  • Dec 17, 2014
If the suspension is feeling really loose and you're on the stock setup, then it's possible that you've got worn shocks, which will make the stock suspension feel more bouncy and likely very loose. Push down on the front of the car and see if it just comes back up or if it bounces and do the same with the rear. If either bounces, it's worn shocks or struts (sounds like it might be shocks). You could replace the shocks or struts and that'll probably fix your issue or you could get a set of lowering springs and some koni or tokico shocks and struts and I guarantee that you won't have a problem with loose suspension again
As for the front end, as COramprat said, get your alignment checked, sounds like the front end alignment might be off somewhere.
For the squeak, go to your car, open the trunk and stand on the edge of it and jump up and down. If you hear a squeak then it's your rear isolators, if the squeaking is more consistent and doesn't have to do with suspension travel, it could possibly be a worn axle or axle bearing that is causing your problem. I currently have a bad axle seal and bearing so I get some squeaking on the driver side when driving.
rabidscoobie
616
12
48
College Station,TX
Dec 17, 2014
  • Dec 17, 2014
Ok makes sense,it does feel a bit more bouncy especially at hwy speeds.Speed limits here are 75mph,so at 75-80 small bumps in the road does give it a bouncy feel.
I know the shock on the driver side rear looks as if it has been leaking and thats the reason I suspected the shocks.
It is the stock mach 1 suspension,Tokico shocks. After the holidays i already have plans of replacing them,most likely the struts also.I may just get a kit with springs and lower it just a tad while Im already under there.But first I have to pull the damn tranny again to replace a TOB that squeals like a stuck pig.
Its really irritating since I did the entire clutch just over 2yrs ago.Replaced with a RAM clutch and a FRPP TOB.And that bearing squeals.
Which brings me to another question.
I have a Steeda firewall adjuster installed,are these known to cause TOB's to wear faster?Couple mustang owners I know here claim that they do.1 guy said when he had his installed his TOB would start squealing about 1 1/2 after installed,but he says since he went back to stock cable its now been 3 yrs since he replace a TOB. He has a 97-98 GT that he bought new
DIYdudeguy
27
Earth
Dec 17, 2014
#10
  • Dec 17, 2014
  • #10
Yea, that sounds like worn shocks/struts. Oh yea, sorry, I forgot we were talking about a Mach for a sec haha. Either way if you replace them I'd go for some Koni shocks and struts, couple guys I know are running Konis and say they are definitely worth the expense.
I have the whole steeda adjustable cable, FWA, and quadrant setup as well and I haven't had any problems, knock on wood, and I haven't heard of anyone having problems with the TOB as a result of that setup either, if it's adjusted correctly. I have heard that if you tighten the cable too much it can wear out your TOB, but as long as you have it adjusted anywhere between barely touching the fingers of the pressure plate to about 1/4" away, it should be alright. The TOB can get worn out if the cable is adjusted too tightly and the TOB rides on the fingers of the pressure plate even when the clutch is engaged.
The only reason why I've heard people go back to just the stock cable is because they think that the double adjustability of the cable and FWA is pointless and that it can create a high clutch petal engagement or something to that extent. Some people have said that you get a smoother engagement with the stock cable and FWA combination IIRC, but personally I like it better with the shorter engagement.
rabidscoobie
616
12
48
College Station,TX
Dec 17, 2014
#11
  • Dec 17, 2014
  • #11
Thx for the help.
As for the cable, mine sometimes will feel like it's lost it's adjustment, I barely let off the pedal and the clutch starts to grab. Only way to fix is to lift the pedal up and pump the clutch to reset or adjust.
My 01 gt had the same setup and never needed this done.
I have almost decided just to go back to stock cable.
DIYdudeguy
27
Earth
Dec 17, 2014
#12
  • Dec 17, 2014
  • #12
No problem at all man. Do you still have that crappy stock plastic quadrant? If you do, that may be your problem right there.
I can imagine that the stock self adjusting quadrant would throw off the adjustments of the FWA quite a bit.
rabidscoobie
616
12
48
College Station,TX
Dec 18, 2014
#13
  • Dec 18, 2014
  • #13
Yeah unfortunately I do.
At the time I ordered the FWA they were out of stock and just haven't got around to ordering it.
Just don't drive the Mach to much....maybe at most 5000 miles a year,usually not even that.
DIYdudeguy
27
Earth
Dec 18, 2014
#14
  • Dec 18, 2014
  • #14
So there's your problem, so all you need to do is buy that Steeda quadrant, swap it in for that plastic crap and your problem will be solved!
rabidscoobie
616
12
48
College Station,TX
Dec 18, 2014
#15
  • Dec 18, 2014
  • #15
figures.
Well it's been a few years since I had one so remind me, does the steed a quadrant do away with the stock self adjusting mechanism?
If so then that makes a lot of sense.
DIYdudeguy
27
Earth
Dec 18, 2014
#16
  • Dec 18, 2014
  • #16
Yea, the stock quadrant is two pieces and kind of like a ratcheting mechanism IIRC, but the steeda quadrant is one solid piece so the only adjustment is through the cable and FWA.
rabidscoobie
616
12
48
College Station,TX
Dec 18, 2014
#17
  • Dec 18, 2014
  • #17
ok, thx. Knew it was one piece,didn't really remember the stock setup.
Master baiter
46
texas
Dec 31, 2014
#18
  • Dec 31, 2014
  • #18
I had a similar problem with mine. My question is if u put the car in reverse and mash on it does it tend to wheel hop? Mine did. I replaced shocks, struts, isolators, added bigger front and rear sway bars, eibach springs, mm caster camber plates and a monty carlo bar.....still did it. Lower control arm bushings were worn. So i replaced both upper and lowers. They will squeak to. Swap em with poly bushings but remember to grease them good they make a lil more noise but are worth it.
Master baiter
46
texas
Dec 31, 2014
#19
  • Dec 31, 2014
  • #19
Worn control arm bushing will allow the rear end to move around and cause your pulling prob under acceleration.
rabidscoobie
616
12
48
College Station,TX
Jan 1, 2015
#20
  • Jan 1, 2015
  • #20
Thank you.
Excuse my ignorance when it comes to suspension but would that be the rear ,front,both etc.... that causes the movement?
1 of 2 Next Last
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
