having problems with the IAC... details within.
  • Thread starter Thread starter Mike86Stang
  • Start date Start date Dec 23, 2004
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
  • Dec 23, 2004
Well for some reason I had my old IAC valve go nut's on me & then it crapped out. So I put on a new valve & now this IAC doen't seems to be getting a signal from the EEC.
Problems right now are typical of not having the IAC not working. Any reason why the EEC would not be controlling the IAC properly?
C
crunchie12268
599
Manhattan, KS
Dec 23, 2004
  • Dec 23, 2004
how do you know that the EEC isn't detecting the IAC
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
  • Dec 23, 2004
Well I tried it on another car & it worked fine, plus it's new & my car will not start without holding the gas pedal down in the morning & now the TB is whistling (from previous experience I know this is b/c the IAC is not working.
C
crunchie12268
599
Manhattan, KS
Dec 23, 2004
  • Dec 23, 2004
what about testing the connector with a multimeter? If the EEC isn't detecting it then it is way out of my league, but I think that is wierd how it doesn't detect it... I would think that the EEC is working but something else is wrong
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
  • Dec 23, 2004
ss93cobra
1,422
Wilmington NC
Dec 23, 2004
  • Dec 23, 2004
Something wrong with the harness would be my assumption. Have you tried having somebody test it with a breakout box?
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
  • Dec 23, 2004
I checked the continuity of the wiring already.... no dice even tried wiggling the harness with it probed.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 23, 2004
  • Dec 23, 2004
If you can lay hands on an old fashioned dwell meter, you can check the computer feed to the IAC. Back probe the IAC leads and connect the dwell meter across it. With the engine running you should see about midway on the scale with the meter set for 8 cylinders. No reading or the meter pegged in either direction means either bad wiring or a bad computer.
Edit: Use the 4 cylinder scale, not the 8 cylinder. I checked my notes and it said to use the 4 cylinder scale. Sorry about the oops.
If you had access to an oscilloscope, you can do the job more accurately. The waveform should be a square wave with about a 50% duty cycle. The computer increases the duty cycle to speed up the idle & decreases it to slow down the idle.
I would look very closely at the 10 pin connectors and the IAC wiring. Check the resistance between pin 21 on the computer and the white/lt blue wire on the IAC. It should read less than 1 ohm.
See http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif for 86 model engine wiring diagrams
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
  • Dec 23, 2004
Thanks man, it always seems you have the answers I'm looking for
HISSIN50
34
129
Dec 23, 2004
#10
  • Dec 23, 2004
  • #10
yep, Joe is the man.
another thing as an aside, though 99.9% sure it is of no matter: some aftermarket IAC's require being mounted upside down - otherwise they reportedly dont work well at all.
i seriously doubt that is it - but you know how it goes. had i not mentioned that..........
good luck.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
#11
  • Dec 23, 2004
  • #11
Upside down? The bastard wouldn't even fit under my hood!
Rollin down the street pimpin with my IAC sticking out of a hole in the hood NOT
HISSIN50
34
129
Dec 23, 2004
#12
  • Dec 23, 2004
  • #12
seriously, some do have to mount upside down to work right. i have not used one personally that mounted as such (they say how to mount it in the instructions).
LMAO - 'nope, that hole is not for the blower - it is for my IAC.' i would also have a hole for the top of the gerbil wheel (allows one to run a bigger gerbil wheel) to maximize the benefit of the forced induction. i would have an automatic food dispensor for the little guy too (for more reliable, consistant power).
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 23, 2004
#13
  • Dec 23, 2004
  • #13
lol, I've seen stranger things... it looks like a genuine ford part, but I'm going to take off the motor & see what happens.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
