Having real trouble finding a good ground
GToddyT5
553
Hamilton, NJ
I need to ground something but I can't find a good ground near/around the steering column. Any tips? I don't do electrical stuff that much. I'm pretty must just using some ring connectors and grounding it to a bolt.
Use one of the bolts that are holding on the panel directly under the steering wheel, thats what I used for my guages, and it works great. There are two of them right where the panel stops under the wheel. What are you trying to ground?
I realized the power is the problem and not the ground. It's strange, works if I turn it to accessory and then start the engine. Doesn't work if I go straight to starting the engine.
