I was having the same problem with my Granada power conversion. THis may just be the luck of the draw and not mean a thing, but i could not get any more air out. And the calipers are on the correct sides. I put the front of the car up in the air on the hyd jack as high as I could get it. I got one little pop of air out of each side of the front calipers. But, I also found one rear wheel that I thought I had adjusted, but was a bit loose. I still think the pedel goes too far, but it is much improved, not spongy, and stops hard when I nail the brake pedel. So, I did get some air out. Don't know if putting the car up in the air actually helped or not. My thought was to rotate any trapped air around a bit in the caliper housing and get it closer to the bleeder inside the caliper...take it for what it's worth...
