Have a question about possibly changing heads on the new Ford crate engine I just purchased. Then heads are the X 303 GT40 heads with 1.94 intake and 1.54 exhaust valves and all I can find other than that is "they flow significantly better than the 5.0 heads". I also have a new set of "Jegs" 58 cc heads with 2.02 intake and 1. 60 ? exhaust valves, 170 cc intake runners. Will these heads be an improvement over the GT 40 heads? The compression on the engine is 9.1 but I have no idea what combusion chamber volume is on the GT 40 heads. The Jegs heads were rated up to .580 lift I believe. The roller cam in the crate engine is adverstised at 224 @ .50 and .480 lift. Can I and should I change the heads and what about an upgrade on the roller cam..more lift / duration? This is in a street car with occasional trips to the track. I do not know if the Hypereutectic pistons in the engine even have valve reliefs, nor the max lift based on piston/valve clearance. I have the same engine in a Cobra kit car and it runs great but I wanted to increase the HP on the engine for use in the Mustang. I'd appreciate some feedback on the head change and possible camshaft upgrade?
Outlaw66
Outlaw66
I guess you assumed I knew what I was talking about.
And after the swap, did the power you were "missing" register on the seat of the pants meter? I've run both the B & Z and both can't be beat for the price. Second hand B cams can be had for $75, I bought the Z cam new for $115. Both work great. Even the F4TE truck cam works great with 1.7 rockers. In fact, it's the best cam I've ever run with a carb, even though it was never intended as a carb cam.
