I recently put a new dss 306 short block in my 90 lx. WIth alot of other things as metioned in my sig. also some stuff missing probably..anyway, after about 500 miles there was a knocking, found out to be that the thrust bearing on the crankshaft had too much play and was alittle mangled. Sent the block to dss, said they wouldnt cover it for warrenty cause i installed it to the torque converter "wrong". my converter and tranny are perfect, they were checked out afterwards..if i installed it wrong, it would of f-ed my tranny up. so i got screwed by dss there. Now..i got everythign back and assembled by a shop this time..didnt feel like doing it twice..paid a **** load of money..and now..just got it back last week..and i over heat like a mother. Got it blocked tested, to find that there is tons of compression leaking into the coolant system. Im going to run some tests including a compression test first to see what cyl it is. BUT, what do you guys think it is..from experiance. I have thumper heads ported and polished. ...The shop said it could be a cracked block, head, or gaskets not torqued/put on wrong. heres the deal tho, Oil is crystal clean, antifreeze is clean. No white smoke out the exhaust. No fluid leaking into cylinder. I really hope my gaskets are just put on backwards or blown..but then again..why would they blow in the first place..
what happens when u run the car is sometimes it will act like the thermo doesnt even open..fly right past 180 and bury the need at 260 on the gauge. then come back down. or stay up there. and no i didnt let it run when it got that hot lol...if you open the rad. cap and let it run..tons of air bubbles..and fluid within 5 mins come puking up out of the rad.
