head gasket question
Agreed, the gasket has already been compressed. Once compressed you don't really need to re-use them, you (could) re-use it but you will not get as good of a seal as a new gasket will give.
No point in reusing them. Just asking for trouble. Go with the 9333pt1 like grn92lx suggested, I believe they are 15 bucks each and your local parts store should have them in stock.
X7 on getting new gaskets. Remember your going to have to follow the torque sequence when tightening the heads down and you'll have different torque values for the bolts that you use sealant on versus the ones you use oil or assembly lube on.
